Rear Sway Bar, Proper way to remove/install |
yeahmag |
Aug 17 2006, 06:54 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I got the rear sway seperated from the shock bolts using a big wrench and 'popping' them off like a pickle fork would do. What is the correct way to reattach them?
Thanks. -Aaron |
SirAndy |
Aug 17 2006, 07:01 PM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What is the correct way to reattach them? same ... big pipe-wrench werks just fine ... (IMG:style_emoticons/default/smash.gif) Andy |
yeahmag |
Aug 17 2006, 07:04 PM
Just beat them back on? I don't have to do anything like remove the bushing. put it on the shock bolt, then slide the rod over top?
-Aaron |
SirAndy |
Aug 17 2006, 07:08 PM
Just beat them back on? I don't have to do anything like remove the bushing. put it on the shock bolt, then slide the rod over top? don't beat 'em, bushings in the droplink where they belong, put on the round bolt-end, use very large pipe-wrench to press droplink onto the bolt-end ... done ... (IMG:style_emoticons/default/smile.gif) Andy |
yeahmag |
Aug 17 2006, 07:17 PM
I can't quite picture using a pipe wrench... I have a decent sized one that I used for the struts, I'll put it up there and see if anything makes sense.
In a pinch could I use a C-Clamp to squeeze them back together? Thanks. |
SirAndy |
Aug 17 2006, 07:21 PM
In a pinch could I use a C-Clamp to squeeze them back together? whatever floats your boat, c-clamp will work just fine as well ... (IMG:style_emoticons/default/smile.gif) Andy |
Trekkor |
Aug 17 2006, 07:38 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I use ginormous channel locks.
KT |
Aaron Cox |
Aug 17 2006, 10:21 PM
channel locks indeed aaron!
Lo-Fi Version | Time is now: 8th June 2024 - 11:21 AM |
