914: Twin plug kit for $850 article |
JeffBowlsby |
Aug 20 2006, 11:46 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Also found in my new stash of old papers
Attached thumbnail(s) |
Mueller |
Aug 21 2006, 01:24 AM
too bad no pictures of the modifications....
Jake Raby |
Aug 21 2006, 05:06 AM
This is an off the shelf offering...
(IMG:http://www.aircooledtechnology.com/galleries/msheads/slides/Arnett%20manx%20057.jpg) I also have developed a twin plug dizzy for guys that don't care about direct fire, but for those that do I also have carbureted and EFI versions of DIS for the twin plug arrangement. The benefits are HUGE, all my 105+mm bored engines get the trick and I have several Turbo power plants also running it, those that run over 14 PSI boost REALLY need it! Cool article, I read it about 10 years ago.. My first experience with twin plugs was in 2,000 and every since then I have been working toward making them standard on all my engines. It looks like in 2007 this wil be a reality. |
URY914 |
Aug 21 2006, 06:22 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,038 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I've got a copy of that in my files. I can fax to someone if they need a clean copy.
Paul |
thomasotten |
Aug 21 2006, 08:17 AM
Senior Member Group: Members Posts: 1,547 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Does that make it hard to change the plugs?
Jake Raby |
Aug 21 2006, 08:31 AM
Does that make it hard to change the plugs? I include a special spanner for the lower plugs, the position for these plugs to be fit was an extensive process that sacrificed about a doen heads to make the fixturing for! we use 10mm spark plugs from a Ducati engine, they have the proper heat range and are very small, not to mention very long living.. |
Aaron Cox |
Aug 21 2006, 10:18 AM
nice.....
bjorn jacobson |
Aug 21 2006, 03:02 PM
Member Group: Members Posts: 202 Joined: 10-March 04 From: LaCrosse, Wi Member No.: 1,772 |
Good stuff! Thanks for posting the article. I'll have to reread the Excellence article with the twin plug 912.
Brian Mifsud |
Aug 21 2006, 03:33 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
Twin plug heads for Moto Guzzis (hemi air cooled) usa a little iddy bitty chainsaw sparkplug to keep the hole in the head small....
turboman808 |
Aug 21 2006, 03:46 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
SO I could possibly twin plug my 2.7 and then turbo it. (IMG:style_emoticons/default/idea.gif)
That would either explode or be one hell of a scary ass ride!!!! |
Air_Cooled_Nut |
Aug 21 2006, 04:52 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
This is an off the shelf offering... I also have developed a twin plug dizzy for guys that don't care about direct fire, but for those that do I also have carbureted and EFI versions of DIS for the twin plug arrangement. The benefits are HUGE, all my 105+mm bored engines get the trick and I have several Turbo power plants also running it, those that run over 14 PSI boost REALLY need it! Cool article, I read it about 10 years ago.. My first experience with twin plugs was in 2,000 and every since then I have been working toward making them standard on all my engines. It looks like in 2007 this wil be a reality. Really damn cool, Jake. Nice work (IMG:style_emoticons/default/beer.gif) |
Jake Raby |
Aug 21 2006, 05:19 PM
Thanks.. I am now working with a 2.7L EFI/intercooled/Turbo /Twin plugged/ Roller cammed beast that should make 600 usable ponies below 6,000 RPM..
It belongs in "Herbie ExtremeII" and is being taken very seriously....You'll be hearing a lot more about this one- |
jim_hoyland |
Aug 21 2006, 09:15 PM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Out of curiousity: Are there any twin plug 4's around today ? Saw a twin plug 912 at their monthly gathering in Seal Beach recently.
Jake Raby |
Aug 21 2006, 09:36 PM
I have done three in the past 6 months and have 6 more in the works.
Here is the results of one- it was less than 2.4L (IMG:http://www.aircooledtechnology.com/mightyspyder_dyno.jpg) |
Lo-Fi Version | Time is now: 8th June 2024 - 01:40 PM |
