new motor build, the beginning |
DanT |
Aug 23 2006, 07:56 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
here are a couple of shots of the case I am going to be using for my motor build. Since I found a nice case I will not have to pull my motor for cores....I can keep running my car until the long block is completed and then pull the accessories and injection from my current motor. Car won't be down for more than one weekend this way. (IMG:style_emoticons/default/smile.gif)
Attached thumbnail(s) |
DanT |
Aug 23 2006, 07:58 PM
another
DanT |
last one for now
type47 |
Aug 23 2006, 09:03 PM
how are you going to build it up, that is, stock d-jet? carbed RAT monster? 1.8 L-jet (IMG:style_emoticons/default/biggrin.gif)
nine14cats |
Aug 23 2006, 09:13 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
Nice case Dan! (IMG:style_emoticons/default/clap56.gif)
What combo did you settle on? Do you plan on a dyno session after it's done? Curious minds want to know! (IMG:style_emoticons/default/burnout.gif) Bill P. |
nebreitling |
Aug 23 2006, 09:43 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
nice start. i'm interested in hearing more of your plans, and projected completion date!
DanT |
Aug 23 2006, 09:53 PM
still making final decisions. Maybe a stockish 2.0L with bumped compression and a slightly hotter cam....(one of Jake's), or a complete type iv store 2056 kit with the new LE180 heads....still making final inquiries.
I will be using the stock D-jet. If all goes according to plan...rebuild date will be dependent on when I can get the parts from Jake.... I will be picking up the case and a bunch of other parts (basically a short block and some other stuff) next week.... Then I will be calling Jake to place an order for the direction I decide on. Depending on when I get the parts from Jake....projected finish date is somewhere around Jan '07 or sooner....I get kind of antsy once I decide to do a project and just keep working on it every spare minute until it is done.... Happened that way when I got the car back from Paint and Body earlier this year and got the car completely back together in about 2 days. Probably could have motor rebuilt in a couple of weekends with no interuption... (IMG:style_emoticons/default/smile.gif) We will see.... |
Jake Raby |
Aug 23 2006, 10:41 PM
I'll be happy to help you make wise decisions!
Thats a good clean case! GA cases have some issues that other cases do not have, some of these we have only recently discovered. They are not "downers' but they do require precision measurements to be made. we can talk offline about these or you can send me your case for inspection. Looking forward to assisting you! |
craig downs |
Aug 23 2006, 10:48 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
how do you get the case so clean?
DanT |
Aug 23 2006, 10:54 PM
Thanks Jake. I will be getting in contact with you in the next week or two...
I plan on sending the case to Ted at German Precision once I get it home. I will have him check everything out before I start the build... And make any suggestions if he finds anything. Any light you can shed on this process will be greatly appreciated (IMG:style_emoticons/default/pray.gif) |
Jake Raby |
Aug 24 2006, 12:56 AM
I doubt Ted knows of the issues I have recently found with the GA cases. It took me 15 years to note the trend.
Bleyseng |
Aug 24 2006, 11:12 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Could you give us the lowdown or a hint??? (IMG:style_emoticons/default/smile.gif)
Jake Raby |
Aug 24 2006, 11:28 AM
[url=Recent case observations]http://www.shoptalkforums.com/viewtopic.php?t=102432[/url]
ppickerell |
Aug 24 2006, 11:31 AM
914 addicted Group: Members Posts: 1,679 Joined: 14-October 03 From: Pleasanton, CA. Member No.: 1,246 |
Let's see, unh, measure the oil pump housing OD and make sure that the case bore that it fits into has the proper clearance.
DanT |
Aug 24 2006, 11:14 PM
Jake, thanks for the heads up on the deck height. I will make sure to discuss this with Ted when I take the case to him....
I want to make sure this is a one and only one time build... (IMG:style_emoticons/default/smile.gif) your input is greatly appreciated and I will be getting in touch with you after I get the case home. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:14 AM |
