Front brake problem? |
GaroldShaffer |
Aug 27 2006, 11:04 AM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Question about front brakes. I ran our local AX on the 20th, on my 4th (of 6 runs) when I came in to grid it sounded like I had a rock stuck between the dust cover and rotor. I did the back up hit brake trick a few times and it still made that sound. It was coming from the passenger side front. I quickly jacked up the car and pulled the wheel. I didn't find any stones, I turned the rotor by hand and didn't here any noise. I put the tire back on and continued to race and all was good. On the way home I started to hear the "rubbing sound" sound again, but it would stop if a lightly tap the brakes.
I finally have time today to look at this. With the front wheel on or off it sounds like metal rubbing the rotor when I spin the wheel / rotor. It seems to me that pads are making contact with the rotor, but I need to check the venting clearance. I have never messed with brakes before, what should I be looking for? I'm heading off to sears to get a fueller (sp) guage, dial caliper and micrometer. A man gotta have tools for the job. (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/smash.gif) |
Brando |
Aug 27 2006, 11:08 AM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
The venting clearance is only set on the rear brakes for the parking brake. Pull the front pads and inspect them asap.
Eric_Shea |
Aug 27 2006, 11:18 AM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Same exact thing happened to me at Laguna Seca during the 98 Historics.
Wheel bearing. Now... if it is a brake problem it might be a sticky "knockback" mechanism in that caliper. They are designed to knock the piston back toward the rotor offering a higher pedal feel in return. They have been known to be problematic, even loosing a few races because of front brakes overheating in battle. If you decide to do a rebuild, either concentrate on cleaning those mechanisms thoroughly (they reside inside your pistons and ride on the pin inside the caliper) or... break them off. |
Brando |
Aug 27 2006, 01:29 PM
Another way a wheel bearing issue might present itself is when turning slightly left and/or right, you may hear a whine or grinding/metal-on-metal rubbing. Try going in a straight line and start with very small incremental turning of the wheel. I would try at varying speeds as well.
If you're going to pull the wheel for a bearing replacement, might as well check the pads. I believe headrage a year or so ago had a question about an intermittent grinding/rubbing noise, we found that the pad material separated from the backing. That was a fun afternoon in San Pedro (IMG:style_emoticons/default/smile.gif) |
Eric_Shea |
Aug 28 2006, 04:09 PM
What's the word turd? (IMG:style_emoticons/default/confused24.gif)
bd1308 |
Aug 28 2006, 04:14 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
Garold, I just got done with a four corner rebuild of my brakes.
Lemme know if you need help, or even a looksy. b |
Lo-Fi Version | Time is now: 17th June 2024 - 12:45 AM |
