TPS, how's it come off..? |
rmital |
Sep 4 2006, 06:51 PM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
How do you detach the throttle positioning switch from the 2.0L throttle body?? The two screws on the right and left are just for postioning....don't want to f'it up.
Attached image(s) |
ejm |
Sep 4 2006, 07:23 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,694 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Remove the screws and slide it off lifting on the metal tabs the screws go thru. The center part is just a snug fit on the "D" shaped shaft.
rmital |
Sep 4 2006, 07:39 PM
thanks Ed....that was easy.
...it was definitely snug enough that I didn't want to force it off. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:33 AM |
