> lowering the front, yeah it's me again!
PORobinSCHE
post Sep 9 2006, 02:15 PM
Gutan tag! besides the front end rusting out and everything crashing down, how does one lower the front suspension? (IMG:style_emoticons/default/huh.gif)
auf wiedersein
Robin
Replies(1 - 3)
MoveQik
post Sep 9 2006, 04:07 PM
What size wheels can I fit?
Follow your torsion bars back and at the end you will see a bolt that can be turned. Turn one way, car goes up, the other way, the car goes down. I want to say it is a 13mm bolt....
Joe Ricard
post Sep 9 2006, 04:49 PM
CUMONIWANNARACEU
11mm bolt. or 8mm allen / hex key
Lift he front of the car up till the wheels are nearly off the ground. I use a 2x4 across the torsion bars. Floorjack in the middle
PB Blaster is your friend
Clockwise is up Counter clock wise is down.
Get the same amount of threads sticking out the adusters each side set the car on the ground. Bounce and roll car back and forth to settle shocks.
measure and fine tune the side you need to change.
DO NOT go too far. A-arm level to the ground is the LIMIT. You are really stiving for 1/8 to 1/4" lower by the front measured at the donuts.
So.Cal.914
post Sep 9 2006, 05:10 PM
"...And it has a front trunk too."
After you have reached the desired affect in front you can adjust the camber
so your tires don't wear funny on the way to have it aligned.
On top of the shock is an adjustment plate, loosten the allen bolts alittle and
move the plate/shock towards the outside. Move it a 1/4" and step to the front
of the car and eye ball them from a distance of eprox 20'. When they look
vertical tighten the allen bolts and get it professionaly aligned asap.
- Lo-Fi Version Time is now: 14th March 2026 - 01:55 AM
