D1A3 |
Gruppe Neun Vierzehn Südosten ![]() ![]() Group: Members Posts: 362 Joined: 3-June 04 From: Atlanta, GA Member No.: 2,152 Region Association: South East States ![]() |
From Optima's Website regarding RedTop Batteries (http://www.optimabatteries.com/publish/optima/americas0/en/config/product_info/automotive.html)
"OPTIMA batteries withstand the high underhood temperatures associated with these Performance vehicles. The sealed cells make the battery spill-proof, even if you install it on its side! This prevents external gassing and leaking which can damage engine components and limit battery performance." Well, I disagree and here are the pics to prove it... ![]() ![]() ![]() (IMG:style_emoticons/default/WTF.gif) --Jason |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,289 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Are you positively certain that came from inside the battery?
If so, what voltage are you feeding that battery? Are you sure? |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
The only way I got one to "leak" was by overcharging it.....17.5 volts worth. That got it hot enuff to boil.
It actually spewed green shittage out the vents up on to the trunk lid....that is acid, BTW. (IMG:style_emoticons/default/biggrin.gif) I was glad it wasn't in the engine room. I got a new one FOC. |
PRS914-6 |
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None ![]() ![]() |
Could the muffler underneath have raised the temp of the battery excessively? Is the muffler heat shield still installed?
D1A3 |
The car is actually ShadyGrady's here on the board. I broke two motor mounts Friday night on my car during the SEC2006 drive and he let me continue with his track car...
The pics were taken that night when we arrived in Helen, GA (1.5 hour drive). We suspected an overcharge, but it is still being investigated. Fortunately Lewis Broyles brought a spare battery with him when he brought my car up the next morning, so Grady was able to run his car on the SEC drive. I always here "Optima Batteries DO NOT leak." Well, in some cases they do... BTW: Battery acid was all over the trunk lid too. We know it was acid becuase the battery was soaked and the fumes were horrible. --Jason |
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
Lotus 65 was over the other night and showed me his red top that had spit all over his engine compartment.
I never had this happen with mine. |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
something to watch out for...
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Murphy's law says "Anything designed not to leak.....will." Optima is the lesser
of two evils. You could put in a acid resistant battery box. |
anthony |
2270 club ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 ![]() ![]() |
The optima's do have vent holes but they don't vent vapors like normal batteries unless overcharged. It's more like they are leak resistant rather than leak-proof.
lotus_65 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,609 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region ![]() |
it could be that my mount was loose and the battery rocked on the tray some. that's about the only thing i could come up with for a reason... anyway, glad to hear i'm not the only one.
paul (IMG:style_emoticons/default/smile.gif) |
Phoenix-MN |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 ![]() |
I had a red top mounted on its side in my 911 - IT LEAKED! I changed the mounting location and set it up-right. No problems since.
robby750 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 646 Joined: 6-April 03 From: Lexington, Ky Member No.: 521 Region Association: South East States ![]() |
smdubovsky |
Member ![]() ![]() Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region ![]() |
We manufacture specialty battery chargers (www.morningstarcorp.com). The optima is a gel battery. The electrolyte is absorbed in a glass matt (often called AGM - Absorbed Glass Mat) I believe the two black pucks in the top corners are vents. I've never disassembled one of ours, but most batteries have them. If you overcharge the battery (or overheat it, but I have no direct experience there) it will outgass. If there happens to be gel in the way of the vents, it will blow the gel out. It shouldn't vent unless there is a problem though. They are just there to keep the case from exploding (which is REALLY messy).
SMD |
davep |
I agree. I used to head the battery charger manufacturing here some years back. I also have to design lead-acid batteries into some of our products. Heat kills batteries. The heat may be internal from overcharging, or external, say from the exhaust system. Basically, that battery is in the wrong place to start with, it is exposed to too much heat I believe. Overcharging may also be a factor.
JPB |
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 ![]() |
I looked at who wrote that flier and saw it was the past owner of Marlboro. Ya know, the dude who died of lung cancer.
(IMG:style_emoticons/default/beer.gif) Feel energized with Marlboro and Optima! |
D1A3 |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
Yeah as in it's gel filled, not taht it'll survive nuclear fallout.
There's a difference between non spillable and leak free. b |
sgomes |
Electric Member ![]() ![]() ![]() Group: Members Posts: 815 Joined: 6-May 04 From: Campbell, CA Member No.: 2,029 ![]() |
Semantics. Those are used extensively in electric cars. They don't leak if you don't mistreat them. If you are planning to mistreat it then put it in a poly. box.
jonwatts |
no rules, just wrong ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 ![]() ![]() |
I thought one of the selling points of the gel cells was that you could mount them in any position? Looks like that is not true, huh?
bd1308 |
depends on how 'jelly' the jel is...
b |
Lo-Fi Version | Time is now: 6th July 2025 - 02:41 PM |
