> Washers with new master cylinder, where do they go?
Hammy
post Sep 12 2006, 07:28 PM
mr. Wonderful
My new 19mm MC came with two copper washers and I'm not sure where they go. Any help? Thanks. -Z
Replies(1 - 6)
JPB
post Sep 12 2006, 07:36 PM
The Crimson Rocket smiles in your general direction.
They are probably for each side of the banjo bolt for the front brake lines.
(IMG:style_emoticons/default/beer.gif)
Aaron Cox
post Sep 12 2006, 07:53 PM
Professional Lawn Dart
crush washers for the above stated ^^^^^^^^
Allan
post Sep 12 2006, 08:16 PM
Teenerless Weenie
You sure they are not the little ones that go inside the m/c where the feed tubes go?
Hammy
post Sep 12 2006, 08:31 PM
mr. Wonderful
QUOTE(Headrage @ Sep 12 2006, 07:16 PM) *
(IMG:style_emoticons/default/confused24.gif) No clue. I tried them in there under the grommets and they fit but they also fit the brake line holes. They came in a little baggie.
Allan
post Sep 12 2006, 08:35 PM
Teenerless Weenie
If you don't have any under the grommets I would guess that is where they go. If you look at the Haynes manual it'll show them.
Not sure what purpose they serve.
So.Cal.914
post Sep 13 2006, 12:18 AM
"...And it has a front trunk too."
QUOTE(Headrage @ Sep 12 2006, 07:35 PM) *
Because of vibration, it's so the rubber grommets don't wear holes in the cast
iron M/C body. (IMG:style_emoticons/default/wacko.gif)
- Lo-Fi Version Time is now: 13th July 2025 - 07:57 PM
