Full Version: Washers with new master cylinder
Hammy
My new 19mm MC came with two copper washers and I'm not sure where they go. Any help? Thanks. -Z
JPB
They are probably for each side of the banjo bolt for the front brake lines.
Aaron Cox
crush washers for the above stated ^^^^^^^^
Allan
You sure they are not the little ones that go inside the m/c where the feed tubes go?
Hammy
QUOTE(Headrage @ Sep 12 2006, 07:16 PM) *
confused24.gif No clue. I tried them in there under the grommets and they fit but they also fit the brake line holes. They came in a little baggie.
Allan
If you don't have any under the grommets I would guess that is where they go. If you look at the Haynes manual it'll show them.
Not sure what purpose they serve.
So.Cal.914
QUOTE(Headrage @ Sep 12 2006, 07:35 PM) *
Because of vibration, it's so the rubber grommets don't wear holes in the cast
iron M/C body. wacko.gif
