Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,827 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California ![]() |
My new 19mm MC came with two copper washers and I'm not sure where they go. Any help? Thanks. -Z
JPB |
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 ![]() |
They are probably for each side of the banjo bolt for the front brake lines.
(IMG:style_emoticons/default/beer.gif) |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
crush washers for the above stated ^^^^^^^^
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
You sure they are not the little ones that go inside the m/c where the feed tubes go?
Hammy |
You sure they are not the little ones that go inside the m/c where the feed tubes go? (IMG:style_emoticons/default/confused24.gif) No clue. I tried them in there under the grommets and they fit but they also fit the brake line holes. They came in a little baggie. |
Allan |
If you don't have any under the grommets I would guess that is where they go. If you look at the Haynes manual it'll show them.
Not sure what purpose they serve. |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
If you don't have any under the grommets I would guess that is where they go. If you look at the Haynes manual it'll show them. Not sure what purpose they serve. Because of vibration, it's so the rubber grommets don't wear holes in the cast iron M/C body. (IMG:style_emoticons/default/wacko.gif) |
Lo-Fi Version | Time is now: 13th July 2025 - 10:44 AM |
