alternator belt off, how to put back on |
nycchef |
Sep 13 2006, 05:01 PM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
the alternator belt on a 2.0 has popped off. not my car but a new guy who isn't as well versed in the type 4 engine as i am.(he just got it and has not made as many mistakes as i have, dr.evil you can stop laughing now) how can i help him?
Leo Imperial |
Sep 13 2006, 07:34 PM
Do you have to use so many cuss words? Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None |
I did this on your car 2 months ago (IMG:style_emoticons/default/dry.gif) You were watching (IMG:style_emoticons/default/blink.gif)
Rouser |
Sep 13 2006, 07:52 PM
Anti-Post Whore Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 |
Anybody out there know what section & page in the Haynes 914 Repair Manual this procedure is located in? Unfortunately, I don't have mine handy.
cooltimes |
Sep 13 2006, 08:39 PM
Advanced Member Group: Members Posts: 2,508 Joined: 18-May 04 Member No.: 2,081 Region Association: None |
Anybody out there know what section & page in the Haynes 914 Repair Manual this procedure is located in? Unfortunately, I don't have mine handy. I don't have a Haynes. Clymer manual has it on page 162 Autobooks Manual is on page 47. The Autobook version is shortest. I can type it into a post reply if you need it. MikeCool |
So.Cal.914 |
Sep 13 2006, 09:28 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
From the back. There is a sheet metal plate that covers the alternator, on
the left at about 11:00 there is a ovel shaped hole(and plug) in the plate to access one of the two bolts that holds it in place. That paticular bolt is the adjuster bolt the other is at about 4:00. Loosten both a couple of turns slip on your belt, I use a long breakerbar to gently pull the alt back to the left to tighten the slack in the belt. Tighten the bolt(allen I believe) at 11:00 and then the other. |
jk76.914 |
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
What year is it? Does it have AIR? If so, you're in for some fun. The pulley for the AIR pump is on a sort of a tripod affair that straddles the blower. It has to come off first. Looks easy- 3 M6 bolts- but once they're off, the thing is aligned with roll pins. Probably frozen fast! Oh yeah, and you can't even see the other pulley, the three bolts, muchless the rollpins.
Hopefully, he doesn't have a '75 or '76 so he won't have to deal with it... Good luck! Jim PS- found this picture of a 912E. You can see the extra pulley and the three M6 bolts I was talking about..... Again, I hope you don't have to deal with this... |
nycchef |
Sep 14 2006, 06:58 AM
Hopefully, he doesn't have a '75 or '76 so he won't have to deal with it... thanks guys, don't think its a 75 or 76 will try to get my haynes out of my car and give it a try. p.s. leo, thanks i forgot about mine but now that you mention it... it was done from the bottom, on a lift, by walters mechanic, while WE watched. see you tonight. |
Lo-Fi Version | Time is now: 9th June 2024 - 01:41 PM |
