4 bolt to 5 bolt conversion in Philly, 4 bolt to 5 bolt help |
FB914 |
Sep 15 2006, 05:37 PM
74 alaska blue 2.0 Group: Members Posts: 63 Joined: 1-March 05 From: Philly Member No.: 3,689 |
Hi all:
How hard is the 4 bolt hub to 5 bolt hub conversion to do? Where do I find the parts - please don't say ebay! I have the 15 inch fuchs, all I need is the hardware/parts. Is there anybody in the Philly area who knows how to do this who can be bought/coerced/fed a lot of beer and steaks to bribe them into helping? Do I need to pay a professional? What will it cost me (ballpark)? Thanks for the responses - the group is always very helpful. Frank B West Chester PA (IMG:style_emoticons/default/jsharp.gif) (IMG:style_emoticons/default/beerchug.gif) |
JPB |
Sep 15 2006, 05:51 PM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Eric Shea does them in the best possible way. If you wanna do it right and have satisfaction of the conversion for as long as you own your car then he's the man.
(IMG:style_emoticons/default/beer.gif) Look him up! |
Lou W |
Sep 15 2006, 05:56 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
wilchek |
Sep 15 2006, 07:38 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
Once you get the parts it should be an weekend job while drinking beers. i am about 40 minutes from you let me know if u need a hand. Check out the resouce forum here for info on 5 lug hubs
Dan |
Spoke |
Sep 15 2006, 07:52 PM
Jerry Group: Members Posts: 6,990 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I'm preparing to do a 5-lug conversion with complete 911 front suspension including steering rack & underbody sway bar and 4-to-5 lug converted rear trailing arms.
The hardest part is finding the equipment. The easy part is mounting it. The 911 front end just bolts on, and the rear 4-to-5 lug rear arms should exactly replace the existing arms. Time consuming work but not unreasonable in complexity. OK, I won't tell you that I got the entire 5-lug suspension from a dude on Long Island from Ebay for $450. My rear arms are not Eric Shea but his look fantastic for a good price. For the front, you could go the 4-to-5 lug converted rotor way or look for 911 struts or entire 911 front end like I have. Look on Ebay, here, Pelican for 911 pieces. Spoke Attached image(s) |
So.Cal.914 |
Sep 15 2006, 09:58 PM
Just a footnote, When you do the front end remember if you do have the rotors
redrilled you will have to do the same everytime you have to change them. If you go 911 front suspension with hub you just have to replace the rotor itself. I've seen them for as little as $150.00 and you get bigger brakes. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 09:44 AM |
