Flares, 5-Lug,Studs, Spacers and Tires!!, A little bit of it all under the fender. |
mharrison |
Oct 28 2003, 09:55 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
Hopefully somebody has done this and has a good reference point to answer from:
I have a set of 7" Cookies that I want to put under my fiberglass GT flares. What size tires will fit, and when I convert the lugs to 5-lug, (via a drill and stud) will I need spacers? If so, how thick and what length studs? |
elmonte |
Oct 28 2003, 10:50 PM
Member Group: Members Posts: 225 Joined: 31-March 03 From: Danville.ca Member No.: 499 |
245 50's w/o spacers on the 7's with about 1/2 inch to spare
I'm going with 8 inch rims and my have to file the lip of the fender to get enough room |
Andyrew |
Oct 28 2003, 11:40 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
225's on a 7 in rim. Get more rim and run more tire.. plus a wider rim will make for more tire to the ground vs a skinner rim.ie 9 in rim with 225's will be wider than 225's on 7in rim.
Stock engine doesnt need more than 225. But I like big tires.. dont know how much tire a flare will fit, how wide of flare do you have? Hope this helps Andrew |
SirAndy |
Oct 29 2003, 12:21 AM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(mharrison @ Oct 28 2003, 07:55 PM) I have a set of 7" Cookies that I want to put under my fiberglass GT flares. What size tires will fit, and when I convert the lugs to 5-lug, (via a drill and stud) will I need spacers? If so, how thick and what length studs? 225/50 x 15 all around on 7" cookie cutters ... 1 1/4" spacer in the front 1 1/2" spacer in the back no long studs for me, i have spacers with studs pressed in. so, you bolt on the spacer using the original studs (spacer come with steel lug nuts to do so), then bolt your wheel onto the spacer. NOTE: i don't have redrilled hubs, i have real 5 lug back and front. (IMG:http://www.sirandy.com/pix/914/2003.10.01/08.JPG) |
Lo-Fi Version | Time is now: 11th June 2024 - 03:15 PM |
