Torsion bars and rear springs |
chris914 |
Sep 25 2006, 02:02 AM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
I know this question comes up a lot, but is there any rule of thumb or hard data on matching the torsion bars to rear coils springs for best performance?
I have 140lbs springs in the back. I was thinking of getting 180lbs. What size torsion bars are good to keep everything balanced with both? The cars only purpose is for autocross use. |
DanT |
Sep 25 2006, 09:07 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
I know this question comes up a lot, but is there any rule of thumb or hard data on matching the torsion bars to rear coils springs for best performance? I have 140lbs springs in the back. I was thinking of getting 180lbs. What size torsion bars are good to keep everything balanced with both? The cars only purpose is for autocross use. With 180# rears, use 21mm front torsion bars with a 19 mm stock or adjustabel front sway bar. NO rear bar with this set up....If you have a rear bar with this combination you will get too much oversteer. do you have Koni's or Bils? |
chris914 |
Sep 25 2006, 11:15 AM
I know this question comes up a lot, but is there any rule of thumb or hard data on matching the torsion bars to rear coils springs for best performance? I have 140lbs springs in the back. I was thinking of getting 180lbs. What size torsion bars are good to keep everything balanced with both? The cars only purpose is for autocross use. With 180# rears, use 21mm front torsion bars with a 19 mm stock or adjustabel front sway bar. NO rear bar with this set up....If you have a rear bar with this combination you will get too much oversteer. do you have Koni's or Bils? Bils sport |
Lo-Fi Version | Time is now: 3rd June 2024 - 02:58 AM |
