Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
I have been using NGK B8ES plugs in my SIX.
Seems to be nothing but great performance. Is there a better plug? I pulled one out today and it was dark tan/gray. What does the NGK code mean, anyway? thanks KT |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
I think mine are B7ES
I think the 7 is heat range and S is for Suppresion. |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
NGK's rock!
you have a cdi box.. you can go to a colder plug if it doesnt foul (8 is up there tho) NGK website lists what the codes mean... the number (8) is opposite to bosch.... i thibk NGK states a b6ES for a 914/4 .. and i went to a colder plug 5 or 7.... cant remember probably 7 |
Trekkor |
Yeah, I think I'm running a .045 gap, too.
KT |
Joe Ricard |
.050 gap with a Hyfire box and Mallory Pro E coil. and Magnacore wires.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,046 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
there are some really sweet racing plugs out there if you build that new high compression engine.... but they get kinda pricey though the one's I'm coveting right now are $$$$, but provide actual clearance and actual dyno hp..... brant |
Joe Ricard |
Ain't ya going to share?
show me the numbers |
Aaron Cox |
Trekkor |
QUOTE bosch blue.... I have that. KT |
Aaron Cox |
Cap'n Krusty |
B8ES is a REALLY cold plug. Like what you'd run in a 2.4 911S with MFI if you only drove it on the highway. The Cap'n
Aaron Cox |
Trekkor |
I'm open to suggestions.
KT |
Aaron Cox |
Trekkor |
Yes...
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
Bosch Supers.
Aaron Cox |
MSD box reccomends an MSD high output low impedance CDI coil...
Mallory Hyfire box reccomends the same... you will like the small packaging of a mallory promaster Ecoil... the difference is in the resistance. bosch blue coil ~ 3ohm. CDI coil. 0.9 ish ohms.... dont exactly recall.... big difference. your plugs are fine if they arent fouling. (cold enuff) AA |
Trekkor |
I think the Blue coil was one of the acceptable coils for both the MSD and Pertronix applications.
I noticed today that the stickers on my blue coil are shriveled, as if from heat? (IMG:style_emoticons/default/confused24.gif) KT |
bd1308 |
coils get hot, they shouldnt explode though.
brant |
Lo-Fi Version | Time is now: 3rd September 2025 - 07:49 AM |
