Tach question |
Tach question |
HCRDAN |
Sep 30 2006, 04:47 PM
Member Group: Members Posts: 113 Joined: 24-September 06 From: Austin, TX Member No.: 6,907 Region Association: None |
Any idea what the problem(s) might be here?
73 914 2.0L, not driven much by prior owner. Tach works intermitently. May work well for a while, then the needle gets stuck somewhere. Last time it was around 3K RPM, today at 2.2K. Then sometime in the future, it will start to work again. Second problem is the turn signal indicators in the tach. Sometimes they both flash, sometimes neither flash, when I put on turn signals. Signals on the outside work just fine. When I put on emergency flasher, all lights blink as they should on the outside, but nothing blinks on the indicator lights in the dash. Any ideas? Are these related or separate problems? Thanks DG |
Tobra |
Sep 30 2006, 05:38 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
perhaps dirty contacts on the signal indicator bulbs.
My tach does the same thing, I think it is a loose or corroded connection in mine, where it plugs into the back of the tach. |
HCRDAN |
Oct 1 2006, 05:39 PM
Thanks for the feedback.
I pulled the tach today. With it out, I could see that there are two separate bulbs, one for each directions (left/right), and both flash when the turn signal is engaged either right or left. I uess I'll try a new flasher rela to see if this is the problem. I also replaced the tach with another that I had laying around to see if the sticky needdle is a tach issue, or a sender issue. A few days driving will tell. I'll then have the original tach repaired. Thanks for the help. |
ClayPerrine |
Oct 1 2006, 05:45 PM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The turn signal bulbs will both flash if you have the wrong bulbs in the outside sockets. Meaing a 2057 instead of an 1157 bulb. It can also be a bad ground. Check each of the bulb grounds, both at the front, in the engine compartment, and above the fuse block. Make sure that they are clean and shiny, and use a star washer to help insure they ground.
A bad ground above the fuse box would also affect the tach function. |
jk76.914 |
Oct 1 2006, 06:05 PM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
If a left bulb is burned out, then both indicators will flash when you turn the left signal on. If a right bulb is out, then they both flash when you turn the right signal on....
This was actually intentionally designed in, so the driver could tell when a bulb was out. It's not the flasher. I figured this out and posted it back in June or July. Good luck! Jim |
jim_hoyland |
Oct 1 2006, 07:39 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Jim, Would you post a link to your previous thread; it really covered a lot of good info. I want to re-read it myself. (IMG:style_emoticons/default/thumb3d.gif)
Jim_H |
HCRDAN |
Oct 7 2006, 09:40 PM
Tach works intermitently. May work well for a while, then the needle gets stuck somewhere. Last time it was around 3K RPM, today at 2.2K. Then sometime in the future, it will start to work again. Second problem is the turn signal indicators in the tach. Sometimes they both flash, sometimes neither flash, when I put on turn signals. Signals on the outside work just fine. OK, so here is an update: Tach: Replaced it with another tach, and this one has not shown same symptoms. So problem is inside the old tach. I'll send it to speedometer.com to have RickBorth work his magic since he is local to me. Turn signals: Made sure I had good bulbs all around. Ended up ordering and replacing the flasher relay. That solved the problem. Thanks for everyone's feedback. |
jk76.914 |
Oct 8 2006, 08:34 AM
Jim, Would you post a link to your previous thread; it really covered a lot of good info. I want to re-read it myself. (IMG:style_emoticons/default/thumb3d.gif) Jim_H Hi Jim, Here's the link. Sorry about the delay, I didn't see your request until today. Jim http://www.914world.com/bbs2/index.php?show...c=47236&hl= |
JPB |
Oct 8 2006, 08:39 AM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Sweet, that explains the blinking problems I just encountered last time I drove it.
(IMG:style_emoticons/default/beer.gif) Good questions. |
hedgehog |
Oct 8 2006, 05:22 PM
Member Group: Members Posts: 50 Joined: 6-June 06 From: Central Calif Member No.: 6,169 Region Association: Central California |
how do I save this thread
Lo-Fi Version | Time is now: 2nd June 2024 - 10:48 AM |
