brake fittings what size? |
dflesburg |
Oct 3 2006, 07:55 PM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
need to install a line lock for a parking brake,
What size fittings are on our brake lines? |
jd74914 |
Oct 3 2006, 08:08 PM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
don't install a line lock for a parking brake
they don't hold the pressure well enough. after a while your car will role away. the brake lines are 5/16IIRC tho |
Aaron Cox |
Oct 3 2006, 08:44 PM
(IMG:style_emoticons/default/agree.gif) they bleed off pressure and bye bye car.....
why not do the johnman 911 ebrake or get a willwood spot caliper setup from marty or renegade |
jd74914 |
Oct 3 2006, 08:57 PM
(IMG:style_emoticons/default/agree.gif) I'd go for a cable operated wilwood stop caliper.
John |
Oct 4 2006, 09:40 AM
Go to your FLAPS and take a piece of brake line with you. The stock lines are a euorpean bubble flare and the fittings are metric threaded.
You need to take a sample with you to be sure that it matches up. Your FLAPS will have generic straight lines that you will need to bend to fit. We have already discussed a line lock, but if that is what you are going to do, that is what you are going to do. They will work for a while. I prefer the 911 e-brake solution, but that is my own biased opinion. Make sure you park in gear. jus tmy $0.02 |
Aaron Cox |
Oct 4 2006, 09:43 AM
hijack - whats your relation to each other? brothers? father-son?
John |
Oct 4 2006, 10:27 AM
flesburg |
Oct 4 2006, 12:44 PM
Senior Member Group: Members Posts: 506 Joined: 22-November 04 From: Pontiac, IL Member No.: 3,162 |
dflesburg,
Or you could just get some wheel chocks. Harbor Freight probably has them, or you could carry a couple of bricks with you. You should also put the car in 1st gear. Or you could get a chain and padlock and always park next to a big sturdy post and chain the car to the post. |
John |
Oct 4 2006, 12:48 PM
Aaron,
Before you hijack again, that would be my Dad. |
dflesburg |
Oct 4 2006, 01:25 PM
what is FLAPS?
dflesburg |
Oct 4 2006, 01:28 PM
As I stated many times,
The only purpose is to pass the inevitable "CHIP's" side of the road safety inspection... Grrr. |
John |
Oct 4 2006, 01:37 PM
A FLAPS is a:
Friendly Local Auto Parts Store |
Lo-Fi Version | Time is now: 10th June 2024 - 03:12 PM |
