What EXACTLY is a ..., Full flow oiling system? |
914werke |
Oct 6 2006, 09:11 PM
"I got blisters on me fingers" Group: Members Posts: 10,119 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
On a type 4 (IMG:style_emoticons/default/confused24.gif)
Aaron Cox |
Oct 6 2006, 09:14 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
iirc, you block off the output of the pump, has a bypass on the cover, and from here it goes to a remote filter, and goes back in thru one of the galley plugs on the case..... bypassing the stock oil filter passages...
not 100% sure that is all the way correct |
Howard |
Oct 6 2006, 09:58 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Back in Dino days...
It was using a bypass that would allow oil to continue recirculating if pressure/flow became too much for the filter and stopped up the works. |
McMark |
Oct 6 2006, 10:31 PM
Howard, you have it backward. What you described is how the stock oil system works. Full flow means all oil goes through the filter.
sww914 |
Oct 6 2006, 11:34 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
My first thought ( haven't thought or talked about it for years) was the same as McMark's statement. I'm getting old, and I used to know more stuff than I do now. Hell, I can barely type anymore.
Mueller |
Oct 7 2006, 12:01 AM
check out this thread on the subject: full flow discussion
Lo-Fi Version | Time is now: 2nd June 2024 - 06:43 AM |
