Listing of injector flow rates?, Prefer measurement in cc/minute |
Air_Cooled_Nut |
Oct 7 2006, 02:26 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
Did a search for "injector flow rate" but got nuthin'. Couldn't find anything in my manuals, either. Does anyone know the stock injector flow rates in cc/minute?
TIA! |
Bleyseng |
Oct 7 2006, 02:31 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
380cc green ones
250cc? yellow ones |
jd66921 |
Oct 7 2006, 02:51 PM
Member Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 |
Dominic |
Oct 7 2006, 03:07 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
http://users.erols.com/srweiss/tableifc.htm
This is a pretty comprehensive list, but they don't list the 914 injectors. |
Mueller |
Oct 7 2006, 03:10 PM
Yellow (1.7L) - 265 cc/min @ 2.0 Bar, 3V, 0.15 mm ± 0.05 mm lift
Green (2.0L) - 380 cc/min @ 2.0 Bar, 3V, 0.15 mm ± 0.05 mm lift as listed on Brad Anders site... going by memory, the stock 2.0 injectors flow enough for something like 250 hp or more !!!! |
Air_Cooled_Nut |
Oct 7 2006, 03:24 PM
http://users.erols.com/srweiss/tableifc.htm This is a pretty comprehensive list, but they don't list the 914 injectors. Search for Bosch # 0-280-150-105...it would appear that is the injector...maybe (IMG:style_emoticons/default/confused24.gif) Thanks guys! |
Air_Cooled_Nut |
Oct 7 2006, 03:27 PM
Yellow (1.7L) - 265 cc/min @ 2.0 Bar, 3V, 0.15 mm ± 0.05 mm lift Green (2.0L) - 380 cc/min @ 2.0 Bar, 3V, 0.15 mm ± 0.05 mm lift as listed on Brad Anders site... going by memory, the stock 2.0 injectors flow enough for something like 250 hp or more !!!! These cc/minute are much larger than what's listed on the given two sites above. What am I missing? |
Mueller |
Oct 7 2006, 03:32 PM
Yellow (1.7L) - 265 cc/min @ 2.0 Bar, 3V, 0.15 mm ± 0.05 mm lift Green (2.0L) - 380 cc/min @ 2.0 Bar, 3V, 0.15 mm ± 0.05 mm lift as listed on Brad Anders site... going by memory, the stock 2.0 injectors flow enough for something like 250 hp or more !!!! These cc/minute are much larger than what's listed on the given two sites above. What am I missing? Well, it is the internet and who knows where the "other" site has gotten thier information. I know some of the Megasquirt and SDS guys here have sent their injectors off to get cleaned and tested, they should have accurate flow rates as well with the documention. |
Mueller |
Oct 7 2006, 03:36 PM
upon looking at the site again, the only numbers I'd trust are the 1.8 flow rates since they are what I've seen on reputable L-jet sites...they show a 2.0 having the same flow and it is a known fact they flow a lot more than the 1.8 or 1.7 injectors
Air_Cooled_Nut |
Oct 7 2006, 03:46 PM
I just so happen to have his URL in my bookmarks and am going thru his site...
http://members.rennlist.com/pbanders/DJetParts.htm Lists the parts along with their VW and Bosch part numbers. For example, the green 2.0L injectors can be part number 0 280 150 019 or 0 280 150 038, depending on the year. |
Air_Cooled_Nut |
Oct 7 2006, 03:49 PM
...Well, it is the internet and who knows where the "other" site has gotten thier information. I know some of the Megasquirt and SDS guys here have sent their injectors off to get cleaned and tested, they should have accurate flow rates as well with the documention. True, true (IMG:style_emoticons/default/wacko.gif) I have a SDS EM-2D and I'm thinking of replacing my stock D-jet with it, and was reading about flow rates from the instructions and was simply curious, thus the questions. |
jk76.914 |
Oct 7 2006, 04:16 PM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
Here's another list, but I think the data are similar. Common to both lists is the fact that the measuring pressure is 3 Bar, or 43.5 lb/sq in, not 2 Bar. Also, most of the early Bosch injectors are either 265 or 380 cc/min. I've wondered what the differences really are that justify different part numbers. Hose config is one- straight vs. elbow or length thereof, but that's all I can imagine. Impedance of the coil could be another- high or low (ours are low). Color is another difference, but that hardly justifies a different part number.
http://www.telusplanet.net/%7Echichm/tech/injectors.pdf I'm using an aftermarket (Niehoff not Bosch) version of the -036. Listed as for Volvo and Mercedes 4.5L. That seems about right as the MB 4.5L engine is .56L per cylinder, vs. our .50L per cylinder, and they're both listed at 380 cc/min. The price was right at $49.99 each brand new from PartsAmerica.com . Also, this chart projects HP/injector @ 3 Bar, which is 53HP for the smaller (265 cc) and 76HP for the larger (380 cc/min) units. That's 304HP across 4 cylinders!!! Jim |
Bleyseng |
Oct 7 2006, 07:27 PM
I think the 2.0L injectors can support alot more engine size. Even with Djet I can adjust the MPS to a serious rich AFT of 10 to 1 pretty easy on a 2056.
jasons |
Oct 8 2006, 09:20 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
FWIW, I just had my 2.0 injectors cleaned and flowed at Witchhunter. The flow test results they sent me for my 4 injectors: 406cc, 408cc, 410cc, and 408cc at 43.5psi.
Lo-Fi Version | Time is now: 11th June 2024 - 09:19 AM |
