Steering Shaft Question, where to find |
kart54 |
Oct 11 2006, 05:34 PM
Senior Member Group: Members Posts: 544 Joined: 27-January 05 From: Ventura, California Member No.: 3,520 |
Hi all,
I have some play in the joints on the shaft that connects the steering box in the firewall to the steering column. (I know, I know, sounds like a personal problem). All kidding aside, the joints are at either end of the shaft and the shaft itself is a little over a foot long. Can the joints be purchased or does the entire shaft need to be replaced? Are new parts available? I've checked the usual suspects and didn't see them listed anywhere. What are they actually called? If they aren't available, anybody have a shaft and the joints in good condition they want to sell? Thanks for any help you can give. Randy "Car 54 Here I Am" |
914Sixer |
Oct 11 2006, 09:09 PM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
The u joints are no longer available from Porsche. The top joint usually wears out. The lower one usually is good. You should be able to go to the want ads and get some. I should have several if you need some. Have you checked the steering column bearings? The lower is usally good and the top is gone. Depending on the your cars year, there are several options. These bearings will make you think you have U joint problems. I suggest you check them FIRST.
914Sixer |
Oct 13 2006, 09:21 PM
911 u joints are direct replacement. I included some pictures.
Attached image(s) |
Lou W |
Oct 14 2006, 12:23 AM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
How much do the 911 replacements costs?
Lo-Fi Version | Time is now: 6th June 2024 - 06:18 PM |
