rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,097 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Attached image(s) ![]() |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,091 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Dude, stay off the CRACK!!!
MrKona |
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None ![]() |
That looks familiar... (IMG:style_emoticons/default/wink.gif)
Attached thumbnail(s) ![]() |
Loser_Cruiser |
Member ![]() ![]() Group: Members Posts: 407 Joined: 4-April 05 From: Bellingham, WA Member No.: 3,873 Region Association: Pacific Northwest ![]() |
Yeah I ve seen that too.
hmeeder |
Dante's Sportscar ![]() ![]() Group: Members Posts: 352 Joined: 21-November 04 From: San Diego, CA Member No.: 3,154 ![]() |
Shaved 5 pounds off the car
rhodyguy |
missed me by that much...just surface. no holes. i batted .500 on those 6 pesky screws that hold the bottom of the rockers. other than that it's a piece o' cake. (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/smoke.gif)
k Attached image(s) ![]() ![]() ![]() ![]() ![]() |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
BTDT Lucky that this was all the damage I found, easy enough fix.
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,971 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
QUOTE BTDT Lucky that this was all the damage I found, easy enough fix. QUOTE ![]() Itsa914: I would poke the surface rust that's visible w/ a screw driver now that you've got part of the jack plate off. Mine looked like that too and it turned out that I had to cut into a bit of the longs as well. You'll at least want to get more of that lower part of whats left of the jack plate and maybe the sides as well where the plate sits flush against the long. Rust can form in there around the spot welds. That way you can get a wire wheel or sanding disk in there and completely get rid of the rust. Removing the part of the jack plate that sits flush against the long can be done without cutting into or damaging the long itself- it's not easy, but it can be done. Just my 2 cents from experience. (IMG:style_emoticons/default/beer.gif) |
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
Spread a bunch of Rust-oleum around in there, it prevents rust according to the ads.
Hee Hee, this is a joke, don't do it. |
GaroldShaffer |
QUOTE BTDT Lucky that this was all the damage I found, easy enough fix. QUOTE ![]() Itsa914: I would poke the surface rust that's visible w/ a screw driver now that you've got part of the jack plate off. Mine looked like that too and it turned out that I had to cut into a bit of the longs as well. You'll at least want to get more of that lower part of whats left of the jack plate and maybe the sides as well where the plate sits flush against the long. Rust can form in there around the spot welds. That way you can get a wire wheel or sanding disk in there and completely get rid of the rust. Removing the part of the jack plate that sits flush against the long can be done without cutting into or damaging the long itself- it's not easy, but it can be done. Just my 2 cents from experience. (IMG:style_emoticons/default/beer.gif) Yep I did all that, everything was cool (IMG:style_emoticons/default/clap56.gif) I'm not a welder, I had a friend do that for me. |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
oh man thats gives me shudders
I have a plan to weld up my cars every few years, next time i'm going for VERY pretty. |
Lo-Fi Version | Time is now: 13th June 2024 - 07:58 PM |
