Circuit Boards |
Circuit Boards |
PORobinSCHE |
Oct 12 2006, 05:12 PM
Member Group: Members Posts: 421 Joined: 22-July 06 From: Orlando,Fl Member No.: 6,484 |
i recently aquired a spare board. i'd like to remove the backing material to inspect the insides. what do you recommend for removing the material? then what should i use to recove it?
thank you in advance Robin (IMG:style_emoticons/default/type.gif) |
bd1308 |
Oct 12 2006, 05:22 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
hair dryer
Marlow |
Oct 12 2006, 06:07 PM
Member Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 |
If you're going through the trouble of removing all the potting material you might as well solder all the joints too. I used black Plasti-Dip to reseal mine, you could use liquid electrical tape too.
PORobinSCHE |
Oct 12 2006, 06:21 PM
If you're going through the trouble of removing all the potting material you might as well solder all the joints too. I used black Plasti-Dip to reseal mine, you could use liquid electrical tape too. that was one of my intentions when inspecting. i am guessing it will need some attention. (IMG:style_emoticons/default/beer3.gif) |
bd1308 |
Oct 12 2006, 08:53 PM
sorry, let me be more complete:
Hairdrier + putty knife.... then carb cleaner to get everything clean with a stiff toothbrush |
Air_Cooled_Nut |
Oct 12 2006, 10:00 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
In the Classics forum:
http://www.914world.com/bbs2/index.php?showtopic=4940 Pictures are near the bottom of the thread. |
bperry |
Oct 12 2006, 10:37 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
sorry, let me be more complete: Hairdrier + putty knife.... then carb cleaner to get everything clean with a stiff toothbrush I actually went another route. I did mine using dental picks, and a thin blade screw driver. However, instead of heat, I did mine while the board was cold and the backing easily flaked off. There was no need for carb cleaner. Discovered it by accident as I started working on it during winter in a non heated garage. --- bill |
PORobinSCHE |
Oct 13 2006, 06:46 PM
i got a chance at work to strip mine. it flaked off fairly easily. i would use a little heat the using a pick,would pop pieces out.
next a thorough cleaning. i plan on using a bit of liquid flux the help the solder to flow. once all continuity is double checked, i plan on clear silicon for a cover. will try and post a few progress pictures later. Roobin (IMG:style_emoticons/default/beer3.gif) |
TheCabinetmaker |
Oct 13 2006, 07:00 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I think a putty knife on the back of the relay board would tear up more stuff than you can fix!!!!!
Lo-Fi Version | Time is now: 6th June 2024 - 09:50 PM |
