Having trouble with carb linkage and accel. cable setup, Carb newb |
Hammy |
Oct 15 2006, 07:14 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
I've set my carbs up just by looking at other pictures, but don't really know if it's right.
My trouble is, I seem to have too much throttle cable. (?) When I push the gas pedal down, it doesn't pull the carbs to fully open, only probably about 1/4 or 1/3 of the way. I'm not sure what I'm supposed to adjust. See attached pic... Do I need to fabricate another throttle bracket or somehow move my current bracket back?; Wouldn't that give allow me to get rid of the slack in the cable and open the carbs all the way? (IMG:style_emoticons/default/confused24.gif) Or is there something I can adjust ? TIA Attached image(s) |
Matt Romanowski |
Oct 15 2006, 07:31 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
It looks like you just have to pull the end tighter were it mounts to the crossbar, although it also looks like you will then be on the *cable* portion, not the solid rod. If that is the case, then you need to either move the bracket or possibly turn it around to get it farther from the crossbar.
Aaron Cox |
Oct 15 2006, 07:34 PM
that bracket is for BUSSES..... and isnt optimal on a 914...
flip the linkage aroud to the front of the carbs... (brackets switchsides... and now the arm will pull from the top) then make a throttle braket that picks up large hole on fan shroud... 3/16 or 1/4 steel flat stock with 2 bends and a hole... (bend it in your vice) i have a pic in my blog... or you can look at how dave at triad does his at triadwestperfomance.com |
Hammy |
Oct 15 2006, 07:40 PM
Thanks guys.
Matt- You're right. It's right on the edge of the rod part at the end of the cable. If I pulled it forward any more it would be on the cable part. Aaron- I'll try your idea. I need to switch the carbs around in order to put the linkage in the front, right? |
Aaron Cox |
Oct 15 2006, 07:41 PM
NO... (you could.. but why?)
take the brackets and linkage off the top of the carbs and swap them side to side... (left side now on right, and right now on left) |
HeloMech |
Oct 15 2006, 08:13 PM
Go Ahead, Get Pistoph! Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California |
this is a pic of the way mine is hooked up.
I copied this layout from Linda's engine with the same configuration from Joe. Attached image(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 09:28 AM |
