Bus engine vs 914 engine |
daveward |
Oct 22 2006, 10:55 AM
Newbie Group: Members Posts: 7 Joined: 4-September 06 From: Northern California, USA Member No.: 6,765 |
For the record, it seems odd that "bus" returns no search results...especially since I was just reading a 'friendly' debate on the merits of using bus heads.
Anyway, on to the question: I will likely end up with two engines needing rebuilds. Which would be the best to start with...assuming the end result will be a torquey, street 2-2.2 liters for a near-stock 914. 1. Bone tired, bone stock '74 1.8, from a 914 2. Bone stock, said to be rebuilt once, '79 2. 0 "GE" engine from a bus Thanks for your help. Dave |
bd1308 |
Oct 22 2006, 10:58 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
Bleyseng |
Oct 22 2006, 12:16 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
For the record, it seems odd that "bus" returns no search results...especially since I was just reading a 'friendly' debate on the merits of using bus heads. Anyway, on to the question: I will likely end up with two engines needing rebuilds. Which would be the best to start with...assuming the end result will be a torquey, street 2-2.2 liters for a near-stock 914. 1. Bone tired, bone stock '74 1.8, from a 914 2. Bone stock, said to be rebuilt once, '79 2. 0 "GE" engine from a bus Thanks for your help. Dave use the 1.8l case and heads for the rebuild. Use the 71mm crank and rods for the rebuild sooo...you can build a 2056 motor using these parts after they are properly reconditioned. The 1.8l heads are a good start with decent valve sizes 41x34 What are you using for induction? Duals carb, Ljet FI?? Get your cam/lifters from Jake Raby or heck buy a engine kit from him instead of buying the wrong parts elsewhere. |
JPB |
Oct 22 2006, 01:32 PM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
The difference is the depth of the pile my friend the depth of the pile. (IMG:style_emoticons/default/biggrin.gif)
Leo Imperial |
Oct 23 2006, 09:47 AM
Do you have to use so many cuss words? Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None |
Good advice. Rebuild the 1.8 914 heads then post the pictures here so they can be called bus heads.
bd1308 |
Oct 23 2006, 10:04 AM
apparently nobody makes mistakes anymore.
davep |
Oct 23 2006, 10:20 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
You need at least 4 characters to search with. (IMG:style_emoticons/default/sad.gif)
(IMG:style_emoticons/default/agree.gif) with the 1.8 case & heads plus the 2.0 crank & rods. |
Bleyseng |
Oct 23 2006, 10:31 AM
Good advice. Rebuild the 1.8 914 heads then post the pictures here so they can be called bus heads. 1.8L 914 heads look the same as 1.8L bus heads sooo (IMG:style_emoticons/default/confused24.gif) still a on the cheap motor would be using the 1.8 heads rebuilt by say Adrian, 2.0L internals on the 1.8 914 case. Decent hp and on the cheap motor. run a good cam/lifter combo!! as a bad cam combo will kill any engine (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:50 PM |
