instrument lights, black... |
rhodyguy |
Nov 7 2003, 08:28 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
as in out. worked, then didn't. reosat doesn't have any effect. everything else seems to work. is there a fuse that controls this?
kevin |
SirAndy |
Nov 7 2003, 01:18 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
yes, there is a fuse. forgot which one tho ...
oh, and if you have a middle-console, check the square heater light. the contacts there are less than a mm apart and have caused blown fuses for the gauges in the past. Andy |
rhodyguy |
Nov 8 2003, 08:06 AM
thanks andy. i had to remove the switch/carpet to adj the shifter. i'll check that asap. i love (IMG:style_emoticons/default/wub.gif) these simple fixit answers. as stated before, "this bb rocks". what do you think a dealership would charge for this stuff?
kevin "allways forward, never straight" |
DNHunt |
Nov 8 2003, 08:14 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Kevin
Had that experience. Wanted the dealer to work on something a couple years ago. They kinda laughed then a salesman came over and suggested I buy a new Boxster. His advice was it would probably cost less to keep it up. Thank God I'm doing all my own wrenching now. Dave |
JWest |
Nov 8 2003, 10:12 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Fuse #7. Check the license lights (same fuse). It's probably the heater light that shorted but you still need to replace the blown fuse.
rhodyguy |
Nov 8 2003, 07:58 PM
andy nailed it. the hot lead was a bit frayed an inch or so back. must have contact to the tunnel and popped the fuse, and yes james it was #7. thanks guys. the switch on the tunnel would have been the last place i would have looked. the old addage "what did you do last" was the obvious answer.
kevin |
Lo-Fi Version | Time is now: 9th June 2024 - 07:51 PM |
