Torsion bar wouldn't come out! |
chris914 |
Oct 28 2006, 07:22 PM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
Hi,
Has anyone ever have a torsion bar that would not just come out? One side came out by hand the other side just will not come out. Also it is not centered in there and when I turned it upside down a ton of rust came out. I don't know if I should even use it if I do get it out. Anyone in San Diego have a set of control arms with the sway bar tabs? lol Attached image(s) |
914Sixer |
Oct 28 2006, 07:34 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
If it will not pull out, drive it out the front. There is only a cap on the other end. They are replaceable. They are only a couple bucks from Porsche. Other choices include PB blaster and or heat.
chris914 |
Oct 28 2006, 07:37 PM
If it will not pull out, drive it out the front. There is only a cap on the other end. They are replaceable. They are only a couple bucks from Porsche. Other choices include PB blaster and or heat. I tried PB blaster and heat and that is the control arm hanging from a chain and a vise clamped to the end of the torsion bar.java script:emoticon(':D', 'smid_4') I don't have a press. |
markasap |
Oct 28 2006, 07:54 PM
Member Group: Members Posts: 111 Joined: 24-March 05 From: topanga ca Member No.: 3,811 |
I just went thru the same thing
squirt some liquid wrench in the back end and let it sit over night. Drill a .250 Hole in the front cap and use a punch and a big hammer. good luck |
chris914 |
Oct 28 2006, 08:11 PM
chris914 |
Oct 29 2006, 10:36 AM
Drilled a hole in the front end last night and filled it liquid wrench type stuff to sit over night. Tried removing it today with a puch and a 5lb hammer. It didn't move a 0.001" th of inch. &^$#$%@&
How is that end cap in there? |
SirAndy |
Oct 29 2006, 12:26 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
How is that end cap in there? just a press fit. if you already got a hole in it, hook something to it and pull out the cap ... that'll give you much better access to the TB ... (IMG:style_emoticons/default/smash.gif) Andy |
Lo-Fi Version | Time is now: 10th June 2024 - 09:40 PM |
