Accel cable, different cable |
spunone |
Oct 31 2006, 10:36 AM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
(IMG:style_emoticons/default/screwy.gif) Replacing throtle cable old one had a white sleeve that went in the tunnel new one does'nt any problems with the new cable??
SLITS |
Oct 31 2006, 10:46 AM
OEM style vs aftermarket? A cable is a cable, but the one without the sleeve could possibly rub against the tube and cut through it besides rusting faster ..... just my thoughts
spunone |
Oct 31 2006, 10:49 AM
Yeah it's the after market Terry cable . Rust do these cars Rust? (IMG:style_emoticons/default/av-943.gif)
SLITS |
Oct 31 2006, 10:56 AM
Well, I thought the Terry cable was supposed to be the ultimate "bling" ... No, these cars do not rust; they just disintegrate!
Chris Pincetich |
Oct 31 2006, 10:59 AM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
My accel cable is sticking and caused concern at this last weekend's AX. Trekkor, Demick, and Bill Eason all suggested I get a new cable, but warned against the aftermarket version cause for some reason it is a bad idea....sounds like it has no housing/sheath on the cable? (IMG:style_emoticons/default/sad.gif)
Matt Romanowski |
Oct 31 2006, 11:01 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
If it is sticking a little you can lube them. Get a motorcycle cable lube device / thingy. You can then inject your favorite lube (WD40, etc).
Brad Roberts |
Oct 31 2006, 12:51 PM
QUOTE My accel cable is sticking and caused concern at this last weekend's AX. Trekkor, Demick, and Bill Eason all suggested I get a new cable, but warned against the aftermarket version cause for some reason it is a bad idea....sounds like it has no housing/sheath on the cable Did you ask them how many different 914's they have worked on? (IMG:style_emoticons/default/biggrin.gif) The Terry's work MUCH better than stock. Probably HALF the drag compared to stock. To this day, I have installed 30+ throttle cables and 20+ clutch cables (all Terry) with NO failures. Just installed two more last night. The key is proper adjstment and proper adjustments of the STOPS!! The factory stops is where people FAIL to properly finish the job. It is one thing to have experience with "your" car, it is completely another to experience 100's of them over the years. B |
Brad Roberts |
Oct 31 2006, 12:54 PM
QUOTE sounds like it has no housing/sheath on the cable? It has a coating on it.. doesnt need the sheath. B |
Chris Pincetich |
Oct 31 2006, 01:18 PM
Yeah, the stop is where the problem started on mine. We (edit: Trekkor) tightned the stop down and it solved the worst of the sticky situation. Now it is real stiff with a little stick. I told all those guys nobody works on my car until I get 12 replies to my question in the 914club Garage! (IMG:style_emoticons/default/av-943.gif)
I'll try the lube, then replace later when the winter hibernation starts. This Terry cable sounds OK then, endorsed by both SLITS and Brad (IMG:style_emoticons/default/beerchug.gif) |
Brad Roberts |
Oct 31 2006, 01:21 PM
HPH has them in stock and Pelican can ship them.
B |
Trekkor |
Oct 31 2006, 05:25 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I run the Terry accel and clutch...I said he could have my spare stock cable that I keep in my tool box if he wanted it. (IMG:style_emoticons/default/wink.gif)
KT |
Brad Roberts |
Oct 31 2006, 05:36 PM
Trek was trying to help you out!! Good place for stock cables..LOL (spares)
B |
Lo-Fi Version | Time is now: 10th June 2024 - 04:45 PM |
