Can I get a measurement?, I do not have a spare part to measure |
jwalters |
Nov 4 2006, 10:05 AM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
Hey guys - would someone please give me the measurement for the exhaust head pipe ( oval section). I need the outer spec sizing and the radius section inside. If at all possible, from a set of 1.7 & 2.0 pipes. But either size will help me out considerably. Thanks ---
J. (IMG:style_emoticons/default/beer.gif) |
jwalters |
Nov 5 2006, 06:43 AM
Hey guys - would someone please give me the measurement for the exhaust head pipe ( oval section). I need the outer spec sizing and the radius section inside. If at all possible, from a set of 1.7 & 2.0 pipes. But either size will help me out considerably. Thanks --- J. (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/confused24.gif) anyone?? (IMG:style_emoticons/default/confused24.gif) |
904svo |
Nov 5 2006, 07:36 AM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Measure the copper gasket used on the exhaust it the same size.
jwalters |
Nov 5 2006, 08:53 AM
Measure the copper gasket used on the exhaust it the same size. Thanks - (IMG:style_emoticons/default/dry.gif) - - I'll just have one express delivered to my door --- seeing as I do not have any parts on hand --- (IMG:style_emoticons/default/rolleyes.gif) |
bd1308 |
Nov 5 2006, 12:33 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
problem solved (IMG:style_emoticons/default/clap56.gif)
jwalters |
Nov 5 2006, 05:44 PM
76-914 |
Jul 14 2011, 12:58 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Hey guys - would someone please give me the measurement for the exhaust head pipe ( oval section). I need the outer spec sizing and the radius section inside. If at all possible, from a set of 1.7 & 2.0 pipes. But either size will help me out considerably. Thanks --- J. (IMG:style_emoticons/default/beer.gif) what measurement do you need? i think stylintrucks have that. (IMG:style_emoticons/default/confused24.gif) my brother bought some parts in there. Whoa ishie. Are you doing time somewhere? I must commend you on reading back 5.5 yr's, though. |
914Mels |
Jul 14 2011, 09:34 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
Hey guys - would someone please give me the measurement for the exhaust head pipe ( oval section). I need the outer spec sizing and the radius section inside. If at all possible, from a set of 1.7 & 2.0 pipes. But either size will help me out considerably. Thanks --- J. (IMG:style_emoticons/default/beer.gif) what measurement do you need? i think stylintrucks have that. (IMG:style_emoticons/default/confused24.gif) my brother bought some parts in there. Whoa ishie. Are you doing time somewhere? I must commend you on reading back 5.5 yr's, though. The shorter side of the copper gasket across the "flats" on the outside is 37mm wide. the long side is 43mm, end to end. The inside "flat" is 30mm across to find your radius. Does that help? |
Lo-Fi Version | Time is now: 10th June 2024 - 01:28 AM |
