running a motor on the ground.., how do I do it? HELP JOE!! |
DrifterJay |
Nov 5 2006, 04:54 AM
I break stuff... Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None |
Alrighty...finally finished putting the motor together...Tranny stabbed into the motor, dizzy/carbs in, plugs hooked up, starter in. Where do I go from here? I dont remember how to do it exactly...I have a gas can and my fuel pump mounted and grounded...where do I run my wires to fire it up...what needs to be connected to start on the floor...completely away from the car...Help!!
-Jared |
DrifterJay |
Nov 5 2006, 05:25 AM
Alrighty...finally finished putting the motor together...Tranny stabbed into the motor, dizzy/carbs in, plugs hooked up, starter in. Where do I go from here? I dont remember how to do it exactly...I have a gas can and my fuel pump mounted and grounded...where do I run my wires to fire it up...what needs to be connected to start on the floor...completely away from the car...Help!! -Jared BUMP...cmon someone!!! I want to hear this beast run before I go to sleep!! |
Spoke |
Nov 5 2006, 06:44 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I ran a 1.8L engine from my 71 914 using the battery, fuel pump, and fuel to power the beast. I just connected the fuel pump with a long hose, cable jumpered to the battery, and disconnected the fuel pump voltage lead and ran it over to the extra engine where I had 2 switches rigged up: a toggle switch turned on power to the fuel pump and coil; a push button switch engaged the starter solenoid.
Worked like a champ. I put a battery charger on the battery since there was no alternator hooked up to recharge the battery during operation. The engine is on a Harbor Freight furniture dolly and didn't jump around at all. Spoke Attached image(s) |
JoeSharp |
Nov 5 2006, 08:10 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Did you get it Jared? If not call me (714) 847-8002
:PERMAGRIN: Joe |
Lo-Fi Version | Time is now: 9th June 2024 - 11:36 AM |
