Passed inspection!, First time being legal in 7 years. |
LowGT |
Nov 12 2006, 01:27 AM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
Well I spent the last year working on this car and today I drove it to the inspection station. After 30min of anxious waiting, mainly because I didn't think they could drive it right, it passed! It'll be the first time the car was registered in 7 years. (IMG:style_emoticons/default/smilie_pokal.gif)
Anyway, I put about 30 miles on it today. Everything was fine but there was a clunk/pop noise that started out faint, and now is pretty loud. I checked the wheel lugs and CV bolts, they're fine. It makes the noise when you begin foward motion, and make it again if you let of the gas. To me it sounds like a bad CV. What do you guys think? Dan |
GWN7 |
Nov 12 2006, 02:11 AM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
Quite possibly the CV....did you check the outer CV bolts too?
Oh.... congrats on the drive (IMG:style_emoticons/default/smile.gif) |
Spoke |
Nov 12 2006, 02:30 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Check CV play by lifting a wheel and hold the inner carrier coming out of the tranny with one hand and move the wheel back and forth with the other. If there is substancial play, it could be CV time. Holding the inner carrier will eliminate play inside the tranny if in gear. Do this with the E-brake off of course. Maybe someone else has a better way to check CVs.
Spoke |
LowGT |
Nov 12 2006, 02:31 AM
VegasRacer |
Nov 12 2006, 06:31 AM
ELVIRA Group: Benefactors Posts: 8,524 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
it passed! It'll be the first time the car was registered in 7 years. (IMG:style_emoticons/default/smilie_pokal.gif) Congrats. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
Grelber |
Nov 12 2006, 10:12 AM
Insert favorite Don Rickles joke here. Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region |
Dan: Congrats on the inspection. It "only" took me 5 tries to get mine to pass (up here in McKinney). FYI: You don't have to let them drive it. They can do a "ride along", and just tell you to hit the brakes, etc.
LowGT |
Nov 12 2006, 04:28 PM
Here she is, it's a proud feeling after a years worth of work. She's a bit rough cosmetically, but the longs and floor pans are rust free. The battery try is still there, but with a lot of surface rust and some pin holes. I'll need to take care of that for sure.
Attached image(s) |
JohnM |
Nov 12 2006, 08:14 PM
914 enduro driver Group: Members Posts: 179 Joined: 23-July 04 From: San Diego Member No.: 2,387 |
Double check axle bolts tight (big castle nut)- simple but sometimes overlooked. John
Allan |
Nov 12 2006, 08:20 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Here she is, it's a proud feeling after a years worth of work. She's a bit rough cosmetically, but the longs and floor pans are rust free. The battery try is still there, but with a lot of surface rust and some pin holes. I'll need to take care of that for sure. Damn!!!! That's a really nice car. |
Bryho |
Nov 12 2006, 08:25 PM
Newbie Group: Members Posts: 39 Joined: 27-May 06 From: Frisco, Texas Member No.: 6,080 |
Congrats!
I too passed Friday morning. Finally Then I went to get it registered and some plates and doooh! I forgot it was Veterans day and that the of the County Offices were closed. Next Friday I should be in business... |
Bryho |
Nov 12 2006, 08:26 PM
By the way, nice ride
tesserra |
Nov 13 2006, 01:13 AM
Member Group: Members Posts: 210 Joined: 26-March 03 From: Lafayette CA Member No.: 479 |
Trans mounts? On and off the gas loads and unloads the mounts.
Easy to check, easy to replace. George |
LowGT |
Nov 13 2006, 02:47 AM
Trans mounts? On and off the gas loads and unloads the mounts. Easy to check, easy to replace. George The mounts are present, but dry and cracked. They need to be replaced. However, while inspecting the mounts I noticed the rear swaybar is pretty tore up from banging against the backside of the trans mounts. I *think* this is where the noise is coming from. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:12 AM |
