Front trunk latch stuck |
RJdiego |
Nov 18 2006, 03:40 PM
Newbie Group: Members Posts: 21 Joined: 18-November 06 From: San Diego Member No.: 7,232 |
Hi,
I'm new to this forum. I'm trying to bring my 914-6 back to life after being stored since 1982. Among many issues is the front trunk release will not unlatch the hood. Any way to manually release it? There must be a way to unlock it if the cable breaks. Thanks, RJ |
thesey914 |
Nov 18 2006, 03:44 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
yes take off front bumper and you can get the release catch through an aperture
You remove the front bumper with two 13mm bolts in each wheel arch. |
JPB |
Nov 18 2006, 04:42 PM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
:agree:Hole thingys behind the old bumper. (IMG:style_emoticons/default/welcome.png)
abearauto |
Nov 18 2006, 05:43 PM
Newbie Group: Members Posts: 45 Joined: 10-May 03 From: washougal wa. Member No.: 677 |
also make sure that when you do get it open that the cable sheath is in good conditon and all the tabs that secure it are holding most important that the clamp at the latch assy is there and tightend to hold the cable housing this makes it alot eaiser to release the front hood
RJdiego |
Nov 19 2006, 01:05 AM
yes take off front bumper and you can get the release catch through an aperture You remove the front bumper with two 13mm bolts in each wheel arch. Thanks, the last time I took the bumpers off was 1979. I thought the bolts were in the trunk. Getting to old to crawl under the car! RJ |
thesey914 |
Nov 19 2006, 06:41 AM
Last time I took off the front bumper I found it easier with the wheels removed and out of the way
jim912928 |
Nov 19 2006, 07:44 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
After you get it open...if you want it to work smooth and like butter. Take the sheath off....take it and the wire component down to your local go cart/motorcycle shop and have them cut a new cable the proper length. Then have them thread the 914 wire into the cart sheath...put it back on the 914 and you'll never get binding again. For me, the total cost was like 12 bucks and I can open the trunk with a 1 finger pull.
Lo-Fi Version | Time is now: 29th May 2024 - 03:28 AM |
