Need Fuel Pump & Regulator Advice, 2.7 /6 w/carbs |
Allan |
Nov 22 2006, 01:18 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Currently I have a facet pump with some wierd Sparco? press and click pressure regulator that seems to fluctuate between 2 and 6 psi.
Can anyone recommend a good pump and regulator set-up that's reliable and will give me a constant 3-4 psi? |
Aaron Cox |
Nov 22 2006, 01:19 PM
CBperformance internaly regulated rotary pump.
solved my fluctuation issues... chuck the facet and dial regulator! |
Aaron Cox |
Nov 22 2006, 01:20 PM
Allan |
Nov 22 2006, 01:25 PM
So, no need for a regulator with the rotary?
Aaron Cox |
Nov 22 2006, 01:27 PM
weed da text....
internally regulated to 3.5 (IMG:style_emoticons/default/smile.gif) none required. and you dont get to hear it... its that quiet (IMG:style_emoticons/default/smile.gif) BTW - i think steve wood is gonna need my tools soon... AA |
echocanyons |
Nov 22 2006, 02:50 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
A peirburg pump and PMO's own regulator is what is usually recomended.
GeorgeRud |
Nov 22 2006, 02:54 PM
The CB pump appears to be the Pierburg one. Not only does it work well, but it is small and can easily be placed by the steering rack to relocate the pump up front.
You can also order them through MidAmerica (the old Tweeks VW site). |
Lo-Fi Version | Time is now: 7th June 2024 - 04:33 PM |
