Wellp, it finally happened, Driver's Side Outside Door Handle Failure |
Brando |
Nov 22 2006, 09:02 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
It was only a matter of time. Thing locks difficulty, will barely unluck and won't open from the outside. Between this and the master/slave clutch cylinders on my 944 going south, I finally have things I can do simply on my cars. Does anyone make repro plastic pieces that go over the door handle to actuate the opening lever in the door yet?
Elliot_Cannon |
Nov 22 2006, 09:05 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Leave the roof off and you don't need to open the door. LOL
Elliot |
Coy |
Nov 22 2006, 09:44 PM
Member Group: Members Posts: 352 Joined: 6-February 06 From: Salem, OR Member No.: 5,537 |
Automobile Atlanta sells a plastic reproduction piece that was reasonably priced. I got two, 'cause you know it's just a matter of time now, until the other side fails.
Grimstead |
Nov 22 2006, 09:59 PM
Cheaky Monkey Group: Members Posts: 835 Joined: 20-March 05 From: Corona, Ca Member No.: 3,789 Region Association: Southern California |
I'm pretty sure I have one for you, if you can wait till early next week when I'm back in town
Cap'n Krusty |
Nov 22 2006, 10:40 PM
GPR, Pelican, almost any P car parts place carries the piece you need. Regular preventive maintenance, i.e., lubing the latch assembly yearly, will prevent this from happening. if you don't do this when you replace the plastic part, you'll soon be back in there. The Cap'n
URY914 |
Nov 23 2006, 08:15 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,038 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I've seen the new black plastic sliders fail if you don't keep things clean and lubed. The problem with the new ones is they bend without breaking. So you go to all the trouble of taking the handle off and it looks good, but doen't work when installed.
Lesson learned: Keep it clean, lubed and use it..... (IMG:style_emoticons/default/happy11.gif) |
Brando |
Nov 23 2006, 09:52 AM
Anyone make a brass or aluminum repro piece? I'd prefer it not to break in the future...
Lo-Fi Version | Time is now: 7th June 2024 - 09:25 PM |
