Cruzing |
Member ![]() ![]() Group: Members Posts: 214 Joined: 23-October 06 From: San Diego Member No.: 7,082 ![]() |
I have a stock oil tank, what about the hoses to connect to the stock 911S oil cooler, any idea's on a good way to do it?
thanks...(IMG:style_emoticons/default/smile.gif) |
michel richard |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 ![]() |
I think you need to be more specific with your question. I understand that you have a stock 914-6 oil tank, in the stock location. What's not clear is what you mean by "stock 911S cooler". There were several different 911 oil coolers over the years, some were the same as on other 911 cars, some not. Also, you don't mention location of the oil cooler. Actually, you don't even say if you mean the on-engine cooler or a front-mounted oil cooler.
There have been a number of threads discussing this, perhaps you can start with a search of the site. A number of members will be glad to help with specific questions. Michel Richard |
Kerrys914 |
Dear, the parts I just sold paid for that part ;) ![]() ![]() ![]() Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 ![]() |
I'll take a guess at the question and here is my answer to my quess;
The stock 911s oil cooler will not work in a 914-6, unless you mod the oil cooler. Do a search on the 914-6 oil cooler and you should see some past threads. You can get OEM hoses if you wish and have funding $$$ or you can make you own with some AN hose and fittings. Cheers |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Do yourself a favor and use the metric adators & AN lines. I've already been through this with stock lines. I used a stock oil tank, hard line and stock 914/6 cooler on a 2.4 T motor.
The fittings on a stock 914/6 oil tank that came on the 2.0 L engine are smaller in diameter than the later engines. I had to change the block fitting to the earlier size on my 2.4 to accomodate the 914/6 hardline. You must have the fitting on the oil cooler welded on and turned 90 degrees so that the hose connection is facing the front of the car or obtain a stock 914/6 cooler. There are two hoses from the tank to the cooler. Their connection is where you drain the oil from the engine oiling system. Depending upon the engine mount, you may or may not be able to use the stock 914/6 hardline (scavenge line from the engine) and then you have to come up with the correct length "short hose) that goes from the hardline to the tank. New hardlines are available from Aase Sales for about $300. The short hose can be obtained new (aftermarket). Pelican sells a "kit" for around $400. Patrick Motorsports has the components listed on their site (metric to AN adaptors), etc. After you have done all of the above, you may or may not find your engine running hot oil temps and wind up having to install a remote oil cooler to supplement the on-board engine cooler. This is where I am at and will find out if the additional cooler fixes my problem or if I just have a glitchy engine. Never do a six conversion!!!! (IMG:style_emoticons/default/mad.gif) !!! it's just a pain in the ass. |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
So if I install a 911S cooler on a 911T, will it be cooler? The Cap'n, feelin' rowdy today .......
michel richard |
Also, you seem to refer to a sportomatic oil tank. I'm not sure what that is , but I'm pretty sure it's not connected to an oil cooler, at least not directly. Very very few 914-6 with sporto, and I suspect very very few 911S with sporto too.
QSL914 |
Newbie ![]() Group: Members Posts: 34 Joined: 20-November 06 From: CALIFORNIA Member No.: 7,238 ![]() |
Go to an industrial / hydaulic hose shop. You can use adapters asuming your cooler has female pipe threads, and hydraulic 100r5 hose with re-usable fittings. The one big problem is the threads on the oil tank. One of them was wierd so I needed to cut off the end of the original hose and weld on a male AN fitting to convert it to standard. I did this for a good friend of mine. I run a hydraulic hose shop in Anahiem, but thats a tad far for you. Down in san diego there is a hose-pros, metro fluid power and a couple parker stores. You will need to bring your cooler and tank so they can identify the threads. Do you need to run hoses to the engine too?
Cruzing |
Happy Thanks Giving everyone,,,... (IMG:style_emoticons/default/smile.gif)
the oil tank is the stock sportmatic that came with the 914/6, the motor is a 1974 911 E/T block, 911S built, the size is 2.4 liter, You have all given great responses, now I need to find the least expensive one to do... (IMG:style_emoticons/default/smile.gif) you can see more info and progress on my project here... http://www.914world.com/bbs2/index.php?showtopic=63648 |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
where did you get the 914/6 sportomatic oil tank??
do you know where the rest of the car is?? |
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,848 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
From Grant IIRC
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
michel richard |
Do you have pictures of that oil tank ?
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,288 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
A large number of the sporto 914/6 tanks were dumped on the market a few years ago. I guess they had a ton left over after production, and there wasn't much of a market for them. They were unloaded at a low price, and sold out quickly I think.
Cruzing |
I have printed out all your options, will find out what Volker recommends and post results later
Cruzing |
I have printed out all your options, will find out what Volker recommends and post results later Called the Porshe dealer, 2-hoses are left in Germany, oil cooler for 914/6 none and hoses connecting cooler to oil tank none are in factory inventory... (IMG:style_emoticons/default/sad.gif) I will be building customs at Volkers, info and pic's soon.. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 1st July 2025 - 08:01 AM |
