Cam, mystery cam |
Cam, mystery cam |
trojanhorsepower |
Nov 12 2003, 10:05 AM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Hi guys and gals
Can any body tell me what cam this is i.e. performance stock. I have read the Weber thread and the stock number don't seem to match the numbers that I have. I could not find a web page for eagle cams, and CB did not list this item #. It does not really matter since I am stuck with this cam, but it might help me tune the motor (if it ever runs!). Thanks again -Pete Attached image(s) |
2teeners |
Nov 12 2003, 10:09 AM
Member Group: Members Posts: 79 Joined: 2-January 03 From: Arlington DFW, TX Member No.: 78 |
I bought one similar at cbperformance.com looks like their version of the stock cam
here's all their cams for type iv's cbperformance eagle typeiv cams I'm wondering, though if it's a carb stock cam. i recall the fi cam has very little overlap (5degrees or so) anybody confirm or deny this? |
2teeners |
Nov 12 2003, 08:27 PM
pulled this from the pelican site archives. your cam seems much more agressive than this stock spec calls out. Slightly less duration than a webcam 73 but less lift.
" Haynes says that the stock cam specs are as follows: intake open @ 12 deg btdc closes @ 42 abdc for duration of 234 deg exh open @43 bbdc closes @ 4 atdc for duration of 227 deg valve lift is .385" |
trojanhorsepower |
Nov 13 2003, 08:26 PM
CRAP!
How bad is that going to screw with my stock FI?? -Pete |
Aaron Cox |
Nov 13 2003, 08:37 PM
sounds like a carb cam (IMG:style_emoticons/default/ohmy.gif)
trojanhorsepower |
Nov 13 2003, 08:49 PM
Shit I hope not!
I know that the PO bought it with the intention of putting the factory FI back on, so unless some one sold him the completely wrong cam (very possible) it should be atleast an FI cam. But who knows. I guess I will just have to wait till I try to fire it up. -Pete |
2teeners |
Nov 14 2003, 03:21 AM
Well, if the webcam 73 is a hotter FI cam, and this is milder than that, It can't be too bad.
I bought the hotter carb cam, but have decided not to build that motor. I wish I'd have bought one like yours for my plans involving FI. (IMG:style_emoticons/default/unsure.gif) |
trojanhorsepower |
Nov 14 2003, 09:06 PM
That's a big relief! (IMG:style_emoticons/default/smile.gif)
Thanks for all your effort 2teener. -Pete (IMG:style_emoticons/default/beerchug.gif) |
DuckRyder |
Nov 14 2003, 10:09 PM
Avatars Mode: OFF because of the recalcitrant few. Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
Its right there on CB's webpage: 2199 =
2199 Stock duration & lift T-2 and 914 camshaft. Fits all VW and Porsche 1700, 1800, & 2 liter engines, exact replacement for factory cam. $99.95 Sounds like it should work fine. (IMG:style_emoticons/default/idea.gif) |
DuckRyder |
Nov 14 2003, 10:14 PM
P.S.
That is about the lamest cam card I ever saw. Crane would close its doors before it turned something that abstract out. God only knows what it is speced at: .006, .004. .050, mm, inches, anyone got a crystal ball to read their mind? One could assume the specs are at the indicated lash, but it does not actually say that. GFL degreeing it. |
2teeners |
Nov 15 2003, 10:36 AM
i went in to order a cam and was stumped by all this, so i did a little further research to find the answer, and here's what I found.
from a post here- I emailed Web Cam recently and asked them for the specs on their replacement for the stock 914 camshaft and they replied: "These are the specs on the stock cam: .302 @ the cam on the intake ( 7.67 mm) .283 @ the cam on the exhaust ( 7.19 mm) Duration @ .050 intake is 210° Duration @ .050 intake is 206° Intake opens -3° Intake closes 33° exhaust opens 31° exhaust closes -5° " You also have to consider the rocker arm ratio.--- I found another post which said Porsche specs are measured at .040, not .050. That's what the Haynes manual calls out, so the numbers are different, but in line. the yellow card from your pic calls out duration which is measured at 0 lift, so that could align as well. so we're dealing with three different ways of cam measurement, that's where the confusion comes in. It would appear you have close to a regular fi cam. (IMG:style_emoticons/default/smilie_pokal.gif) and the hotter webcam 73 for comparison is out at 224deg. duration. I feel better now. |
Lo-Fi Version | Time is now: 11th June 2024 - 04:48 PM |
