Help ...CV joints vw 0 vs vw1 |
CHAFF |
Nov 25 2006, 08:33 PM
Member Group: Members Posts: 167 Joined: 13-September 04 From: Regina, SK Member No.: 2,749 |
Howdy all,
I thought that the outer and the inner were identical...BUT if someone has a set of axles out....can you check which joint (VW0 or VW1) goes to the tranny side or the wheel side? Thx -L Attached thumbnail(s) |
Mueller |
Nov 25 2006, 08:43 PM
there is no differance between the inner and outer CV joint...the different markings you see are more than likely just for manufacturing id
CHAFF |
Nov 25 2006, 08:45 PM
Mueller |
Nov 25 2006, 08:48 PM
Thanks man, I thought so cause they're physically identical. Cheers -L there is no differance between the inner and outer CV joint...the different markings you see are more than likely just for manufacturing id manufacturing tolerances..... |
Lo-Fi Version | Time is now: 8th June 2024 - 04:29 PM |
