HPMX carbs |
HPMX carbs |
fall-apart-dave |
Nov 26 2006, 08:32 AM
Member Group: Members Posts: 61 Joined: 23-September 06 From: Northumberland, UK Member No.: 6,898 |
Alreet!
Does anyone know if HPMX carbs have ports for a vacuum advance dizzy? If not, can someone point me in the right direction.... Port my existing manifolds, or get a bosch 009 dizzy and maybe an electronic ignition? Cheers Dave |
JoeSharp |
Nov 26 2006, 08:36 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
The beest dizzy we found for cheep is the 050.
:PERMAGRIN: Joe |
SGB |
Nov 26 2006, 08:51 AM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
The stock diz with ports blocked will work also, but not quite as well as others. 009s are poorly made these days, and the curve on the 050 is better too.
Chogokin |
Nov 26 2006, 12:57 PM
Member Group: Members Posts: 173 Joined: 17-April 06 From: Pensacola, FL Member No.: 5,878 |
I have the HPMX carbs, and they do have the vac ports on them, I am running a dual advance SVDA from aircooled.net, works pretty good for me. The only real problem I have with the HPMX is proper jetting, one of these days when I have time (and money (IMG:style_emoticons/default/biggrin.gif) ) I will get our local expert over here to help me out with that.
fall-apart-dave |
Nov 26 2006, 04:27 PM
I have the HPMX carbs, and they do have the vac ports on them, I am running a dual advance SVDA from aircooled.net, works pretty good for me. The only real problem I have with the HPMX is proper jetting, one of these days when I have time (and money (IMG:style_emoticons/default/biggrin.gif) ) I will get our local expert over here to help me out with that. Where abouts are the ports? I can't see them, but then I've never used vacuum advance ports before either! What size pipe do I need? And I'm guessing a T-piece is needed too, right? I have 44's, and a 1.7 (but I am planning a bigger lump hence bigger carbs!) |
Lo-Fi Version | Time is now: 1st June 2024 - 12:44 PM |
