Wiring, Where do these things go! |
stang99914 |
Nov 26 2006, 09:07 PM
Newbie Group: Members Posts: 2 Joined: 26-November 06 From: Knoxville Member No.: 7,265 |
O.k. I have a '73 2.0 with the original fuel injection. I'm finishing up a job that was started by someone else. The engine was taken out to be rebuilt and I've got the engine back in and most of the wiring in, but I have some leftovers! close to the throttle body, there are 3 small white wires that have a female end on them. I can't seem to find their male counterparts. Does anybody know they might possibly go?
Thanks for the help |
tracks914 |
Nov 26 2006, 09:13 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
The same wires on my 72 are brown and they all go to a gang ground on the top of the engine case.
Not that yours are this but that would be my first guess. |
Dr Evil |
Nov 26 2006, 09:41 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
There should be a multi male end on one of the case bolts on the top of the engine case arround or under your intake plenum. those are probably all of your injector grounds and they all go to the same ground I described.
Good luck and (IMG:style_emoticons/default/welcome.png) |
Dave_Darling |
Nov 26 2006, 09:48 PM
If by "small" you mean aobut 1/4" or 6mm, and each of those connectors has two white wires crimped into it, then those are indeed the grounds that them two (up there!) are talking about. If they're about 1/8" (3mm) wide they should be hiding in a plastic connector body.
--DD |
SirAndy |
Nov 27 2006, 01:59 AM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Does anybody know they might possibly go? ground for your injectors. there's supposed to be a male connector on one of the top case-throughbolts right next to the throttle body. (IMG:style_emoticons/default/smile.gif) Andy |
stang99914 |
Nov 27 2006, 05:01 PM
Thanks to all who replied to my message. I too beleived that were grounds for the injectors but was looking for an affirmative before I went any farther. Thanks again, there is a lot of great info here on the forum.
Lo-Fi Version | Time is now: 8th June 2024 - 10:58 AM |
