What size wrench fits this nut??, Removing shock from trailing arm |
GaroldShaffer |
Nov 12 2003, 01:16 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Working on removing the shock from the trailing arm. I don't
have a big enough wrench for the bolt that holds the lower shock to the trailing arm. What is size wrench do I need? Looks like another tool run to Sears (IMG:style_emoticons/default/cool_shades.gif) - Garold |
seanery |
Nov 12 2003, 01:23 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
do you mean the lower shock mount with the rear sway bar ball mount?
27mm |
GaroldShaffer |
Nov 12 2003, 01:26 PM
yep that's it.
Rusty |
Nov 12 2003, 01:27 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,942 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Channel locks. (IMG:style_emoticons/default/smash.gif)
seanery |
Nov 12 2003, 01:28 PM
27mm is also the steering wheel nut size.
Did you ever get that situated? |
GaroldShaffer |
Nov 12 2003, 01:40 PM
QUOTE Did you ever get that situated? Yep, it was missing the washer. |
Qarl |
Nov 12 2003, 11:59 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Adjustable crescent wrench!
redshift |
Nov 13 2003, 12:02 AM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
QUOTE(kellzey @ Nov 13 2003, 01:59 AM) Adjustable crescent wrench! Is that metric? M |
Lo-Fi Version | Time is now: 11th June 2024 - 04:30 AM |
