Case Sealant.....Pic |
415PB |
Nov 14 2003, 09:11 PM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
Would this sealant be okay to use to seal my case? I read somewhere to not use silicone based sealant. I wanted to put my case together this weekend and don't really want to order sealant, unless I have to. Is there any reccomended sealant that I can pick up locally?
Thanks, Rod Attached image(s) |
Aaron Cox |
Nov 14 2003, 09:12 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
as the "how to rebuild a volkswagen engine" book said. i used lots of Permatex 3h , (aircraft grade sealant). works good.
got it at FLAP's (IMG:style_emoticons/default/cool_shades.gif) |
LS6/914 |
Nov 14 2003, 11:01 PM
Never leaves the shop member Group: Members Posts: 301 Joined: 1-October 03 From: Port Townsend,WA Rivabelosa/Madrid ESP Member No.: 1,215 Region Association: Pacific Northwest |
Through the years I have used many types. I currently use GM part #1052943. Its made by permatex, red in color. We use it to seal the Cadillac Northstar V8 lower case & crank cradles, works great no leakee. (IMG:style_emoticons/default/beer3.gif)
McMark |
Nov 15 2003, 03:16 AM
Jake uses the aircraft sealant. Buy that local. Use what's proven on hundreds of engines.
DuckRyder |
Nov 15 2003, 07:10 AM
Avatars Mode: OFF because of the recalcitrant few. Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
QUOTE(LS6/914 @ Nov 15 2003, 01:01 AM) Through the years I have used many types. I currently use GM part #1052943. Its made by permatex, red in color. We use it to seal the Cadillac Northstar V8 lower case & crank cradles, works great no leakee. (IMG:style_emoticons/default/beer3.gif) I'm glad I'm not the only one that thought of that. We used to use it on transmissions. Its expensive though. |
Mark Henry |
Nov 15 2003, 09:03 AM
QUOTE(415PB @ Nov 14 2003, 07:11 PM) Would this sealant be okay to use to seal my case? I read somewhere to not use silicone based sealant. I wanted to put my case together this weekend and don't really want to order sealant, unless I have to. Is there any reccomended sealant that I can pick up locally? Thanks, Rod DO NOT USE SILICONE ON CASE HALFS!!!! (IMG:style_emoticons/default/chair.gif) Use the Permatex 3h on one case half only, make sure the surfaces are clean and oil free. I do use a bit of the Silicone on the paper gaskets, just a bit between the fingers rubbed into them. I never have leaks. |
415PB |
Nov 15 2003, 09:21 AM
Thanks guys, I'm on my way to pic up some 3H.
Lo-Fi Version | Time is now: 2nd June 2024 - 06:10 PM |
