seeking rotissery in north carolina, loaner or rental/ prefer tested, have not done, nerves |
chasingsummer1 |
Dec 26 2006, 07:08 PM
Newbie Group: Members Posts: 13 Joined: 15-June 03 From: hickory NC Member No.: 825 |
gave up trying to sell car, so i need a rotissery, i am located near greensboro, nc. tight budget, help locating is appreciated
chasingsummer1@aol.com |
VaccaRabite |
Dec 26 2006, 08:23 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
If you have a welder, they are cheap and easy to make. You will pay less in the long run making one then renting one.
Besides, nothing like welding fresh 1/8 in thick walled steel tube to raise you confidence with a welder. Goes together easy as pie, way easier then sheet metal. I learned to weld making mine. If I can do it.... Zach |
John |
Dec 26 2006, 08:33 PM
here is one I drew most of the way
Attached File(s) ROTISSERIE.pdf ( 253.05k ) Number of downloads: 104 |
chasingsummer1 |
Dec 28 2006, 07:04 PM
do not have a welder, hoping to braze in patches, will not know exactly what i have till i can get a good look at.
has anyone ever used 2 engine stands? any idea how much a 914 would weight stripped down? brian |
VaccaRabite |
Dec 28 2006, 07:25 PM
do not have a welder, hoping to braze in patches, will not know exactly what i have till i can get a good look at. has anyone ever used 2 engine stands? any idea how much a 914 would weight stripped down? brian Mine is actually built off of two engine stands form harbor freight (the $30 ones), and many of the home built ones are based off a pair of engine stands. If you are good at brazing, you can do it, but you would really be better of getting a welder. If you are thinking that your car is going to need a rotesserie, buy a mig welder. It is money very well spent. The PO somewhere down the line with my car brazed in several repairs. When I had to take them out, I was was cursing like a sailor (and being a sailor, I can curse pretty well). Easier to grind out a bad weld then a bad braze. Zach |
chasingsummer1 |
Dec 28 2006, 07:41 PM
i may find out that i need a welder, but if wife knows i have to spend a lot at once, well you know. i am better off sneaking up on that. and i do not trust my first welding experience being on a rotissery. priced a couple engine stands today, sales going on and stuff. for $30 each, i can pick up 2 rated at 750 lbs each. not sure what car should weight. not sure if 1500 total weight ability on stands are enough. should it be, the only other stands i saw were rated at 1500 lbs each, but no sale their, they were 100 each.
when it comes to welding, is their a good but cheap manufacture or model i should be thinking? all input is appreciated, i do not have resourses to make a full restore, but this car has seen 115 on the speedo more times than i dared. and if i do get crazy at times, i need to know it will take it. thanks brian |
VaccaRabite |
Dec 28 2006, 07:55 PM
The stands rated for 750 are fine. That is what I used on mine. But, my car is _totally_ stripped right now. When I start putting things back on, the car will come off the twirler.
When I bought my welder, I bought some steel tube to practice with. I pretty much went right from practice to building the stand. Zach |
Lo-Fi Version | Time is now: 13th June 2024 - 07:04 AM |
