Help w/ CV install |
CHAFF |
Dec 29 2006, 03:16 PM
Member Group: Members Posts: 167 Joined: 13-September 04 From: Regina, SK Member No.: 2,749 |
Hi All,
anyone got a good picture or idea of how to compress the CV's back against the spring retainer to get the dumb c-clips on? Or can a guy just install a thinner "retaining ring" -L Attached image(s) |
r_towle |
Dec 29 2006, 03:28 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Last time I had to do this.
Clamp axle shaft in the vise, dont push against the other CV joint. put everything on, including the clip Get a deep socket, just the right size to push against the clip, yet fit over the end of the axle. TAP the clip in place. If all the parts are clean, and there is no grease/dirt holding you up, it should work. Rich |
CHAFF |
Dec 29 2006, 03:33 PM
I'll give'r a shot.
thx -L Last time I had to do this. Clamp axle shaft in the vise, dont push against the other CV joint. put everything on, including the clip Get a deep socket, just the right size to push against the clip, yet fit over the end of the axle. TAP the clip in place. If all the parts are clean, and there is no grease/dirt holding you up, it should work. Rich |
r_towle |
Dec 29 2006, 03:36 PM
part 8 holds it all in place.
part six needs to be opened and put on the shaft as far as you can by hand, then tap it down....you will feel it snap in place. Rich |
CHAFF |
Dec 29 2006, 03:44 PM
my part 6 doesn't quite make it in. Seems like the internal cv needs to be pressed against 8 to compress it so that it flattens out and then 6 will seat. If I had a press I could probably use that with the socket trick. I don't have the clips as shown in the manual. I have the sharp edge clips (which I presume are factory) - similar to the ones that hold in the adjuster mech in the rear calipers. (But much bigger)
-L part 8 holds it all in place. part six needs to be opened and put on the shaft as far as you can by hand, then tap it down....you will feel it snap in place. Rich |
Crazyhippy |
Dec 29 2006, 09:30 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
i've always used a 20 ton press from Harbor freight... Made an attachment that fits over the c-clip, and has holes so i can push the c-clip down and into the slot...
BJH |
BGman |
Dec 30 2006, 11:20 AM
Greg Group: Members Posts: 87 Joined: 18-January 04 From: Owensboro, KY Member No.: 1,575 Region Association: None |
i don't mean to hijack the thread...but I have always wondered what item 3 "shim plate" does?
CHAFF |
Dec 30 2006, 03:15 PM
CHAFF |
Jan 12 2007, 12:56 AM
K time to update this with my lesson learned mistake.
I had completely dismantled my CV joints - cleaned, lubed, reassembled. I did not notice this....the CV joint will only go back on the CV shaft in one direction. This way the spring retainer gets fully compressed and the clip will fit on properly...otherwise its damn near impossible to press it down (I tried). I also built a cheapo press to put this together. -L Attached thumbnail(s) Attached image(s) |
swood |
Jan 12 2007, 01:05 AM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Wow.
That's intense. My advice is simple.........make sure you put the cv on the axle with the clip befricken for you mate the cv to the stub. Don't friggen ask! |
Lo-Fi Version | Time is now: 28th May 2024 - 12:48 PM |
