Check out my Spread!!, Type-4 Internals that is... |
Britain Smith |
Nov 17 2003, 06:17 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I just got all my engine internals back from the performance coaters. Now if I could just remember how to put this thing back together!
The Piston Top, Combustion Chambers, Valve Faces, and Exhaust Stub Tubes were coated in a Thermal Barrier. The Piston Skirts were coated in an anti-friction coating, and the Valve Springs were coated with a dry-film that absorbes oil. Attached image(s) |
Britain Smith |
Nov 17 2003, 06:18 PM
Pauter 1.48:1 Billet Roller Rockers...
Attached image(s) |
Britain Smith |
Nov 17 2003, 06:19 PM
Dual Springs with 360lb seat pressure and over 0.6" lift, Titanium retainers, and Hardened Valve Keepers.
Attached image(s) |
Joe Bob |
Nov 17 2003, 06:58 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Gonna use a Pinto Weber progressive two barrel??? (IMG:style_emoticons/default/laugh.gif)
Looks nice, good luck. |
Britain Smith |
Nov 17 2003, 10:03 PM
What...does no know what to see my spread...
SirAndy |
Nov 17 2003, 10:14 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Britain Smith @ Nov 17 2003, 08:03 PM) does no know what to see my spread... say what? (IMG:style_emoticons/default/confused24.gif) |
Slowpoke |
Nov 17 2003, 10:27 PM
Member Group: Members Posts: 116 Joined: 1-June 03 From: Tucson, AZ Member No.: 768 |
360 lbs seat pressure??? (IMG:style_emoticons/default/blink.gif) I'm not a type four engine guy, but that seems high! Could you mean open pressure @ max lift?? Or are you using a roller cam? Just curious. My new champion aluminum heads for my V6 Buick (project) only have a 100 lbs seat pressure for a .500 lift cam. Good luck with your engine
Peter |
Britain Smith |
Nov 17 2003, 11:29 PM
Yep...you caught me...I mean't open pressure. I am using ceramic lifters and roller rockers.
-Britain |
Kevin@ojai.net |
Nov 18 2003, 01:06 AM
Member Group: Members Posts: 158 Joined: 9-July 03 From: Ventura & Chico, CA Member No.: 899 |
What type of coating on the skirts?
Brad Roberts |
Nov 18 2003, 02:32 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Basically Kevin.. its a teflon coating or anti friction. In case the pistons expand too much we want some "cushion". With the thermal barriers in place.. we shouldnt have a issue with the skirts rubbing the cylinders, but just in case.. we have the anti friction coating.
B |
Tom Perso |
Nov 18 2003, 05:43 AM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
Those are some nice looking parts!!!!
I'm curious to hear how it works... But, the bigger question being... How much did it cost??? Later, Tom |
Joe Ricard |
Nov 18 2003, 07:26 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Yea Nylocks thats what I should have used.
How much of a cam are you going to run with the ratio rockers? I could sell a kidney or something. I want it I want it I want it. Don't know why I just want it. Not sure why I never considered Nylocks on the rocker studs. I guess I can quit for the day I learned something new. (IMG:style_emoticons/default/pray.gif) |
Jake Raby |
Nov 18 2003, 10:22 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Watch those rockers!
360 open is still pretty high, I run 265 and rev to 7K, with almost every combo we run, and stay controlled just fine. Everyone is different. |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:06 AM |
