OT: does anyone know aluminum?, need ideas on finishing |
vortrex |
Nov 17 2003, 07:13 PM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
I have some large pieces of 1/4" thick sheet aluminum that I will be using indoors as a walkway. from being handled by fork lifts and sitting in the storage the shiny surface has scratches on it. I would like to dull the surface in a uniform manner to hide the scratches and the future wear better. any ideas on the best way to do this? I thought media blasting with a clear coat might be best. what media, what clear coat?
any thoughts are appreciated... |
Katmanken |
Nov 17 2003, 07:22 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Well,
You can sandblast it, bead blast it, sand it or scuff it with a scotchbrite pad. Aluminum by itself is kinda soft. There are some hardcoat anodizes out there but are prolly expensive. Aluminum as a wear surface is gonna be difficult. Mebbe epoxy primers like they use on aircraft. Heck, all the old the stone steps in Europe are dished in the middle. Feet/shoes are abrasive. Ken |
ArtechnikA |
Nov 17 2003, 07:26 PM
QUOTE(vortrex @ Nov 17 2003, 05:13 PM) I have some large pieces of 1/4" thick sheet aluminum that I will be using indoors as a walkway. ... I would like to dull the surface in a uniform manner ... clear coat might be best. what media, what clear coat? flapper wheel, clear power paint. BTW - Comcast giveth, and they taketh away - the DVI HiDef connection quit working Friday, and it's not back yet. maybe someday ... |
vortrex |
Nov 17 2003, 08:01 PM
ken,
yeah there will be a wear issue, but it's just a walkway to the bedroom, so shouldn't be too bad. the aluminum seems to have some sort of coating on it now, it's shiny and smooth. I was hoping for some sort of clear coat. rich, I can't believe it! I never even got around to hooking up my DVI. actually, I was going to do it tonight.. BTW...what's a flapper wheel? |
ppickerell |
Nov 17 2003, 09:47 PM
914 addicted Group: Members Posts: 1,679 Joined: 14-October 03 From: Pleasanton, CA. Member No.: 1,246 |
Clear hard anodize after palm sanding with an random orbital sander is the ticket. Plating shops will have $50-$75 mins on the anodizing though.
vortrex |
Nov 17 2003, 10:14 PM
I'll look into the clear hard anodizing. these are big pieces, $75 minimum definitely won't be an issue.
Lo-Fi Version | Time is now: 13th June 2024 - 03:47 AM |
