| xperu |
Jan 2 2007, 06:24 AM
TEXAS ![]() ![]() ![]() Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None
I have a 1974 FI 1.7, my problem is the relay continues to foul with corrosion. I clean it with electrical contact cleaner, but the problem which clears the corrosion problem for a short time. The car runs flawless except this problem and I really can't rely on the car any longer. I there a way to bypass the relay directly to the fuel pump? Thanks Mike
| rmital |
Jan 2 2007, 08:09 AM
Northeast optimist ![]() ![]() ![]() Group: Members Posts: 1,955 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
I have a 1974 FI 1.7, my problem is the relay continues to foul with corrosion. Mike...how about reaching out to this community on the WTB portion of this site and get yourself a relay board in good condition. Might be a bit safer than hot wiring your pump.... (mike and I have been chasing relay boards "unsuccessfully" on ebay for a while. Can't seem to reach seller's reserve) |
| BMartin914 |
Jan 2 2007, 08:41 AM
||| ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
I have a 1974 FI 1.7, my problem is the relay continues to foul with corrosion. I clean it with electrical contact cleaner, but the problem which clears the corrosion problem for a short time. The car runs flawless except this problem and I really can't rely on the car any longer. I there a way to bypass the relay directly to the fuel pump? Thanks Mike Have you used dielectric grease after cleaning? It should prevent any corrosion from occuring. |
| SLITS |
Jan 2 2007, 06:41 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
And instead of cleaner in a can .... try a wire brush too!
| SGB |
Jan 2 2007, 09:06 PM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
There is more resistance somewhere...
try pulling that big plug near the firewall and cleaning those contacts. And the cleaner in a can isn't close to a good physical wire brushing for accomplishing a better connection. Is the fuel pump fused seperately in an unmolested car? If so, I would check/ clean that area as well. |
| xperu |
Jan 3 2007, 06:22 AM
There is more resistance somewhere... try pulling that big plug near the firewall and cleaning those contacts. And the cleaner in a can isn't close to a good physical wire brushing for accomplishing a better connection. Is the fuel pump fused seperately in an unmolested car? If so, I would check/ clean that area as well. Thanks a lot, I will start cleaning all the connections tonight and using the suggestion from all the 914 buddies. It's a real nice car with only 56K and this is the only problem I have had. Thanks again Mike |
Lo-Fi Version | Time is now: 25th May 2026 - 03:38 PM |
