clutch pedal hard to push |
Hammy |
Jan 9 2007, 08:08 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
I'm noticing my clutch pedal seems generally hard to push. It's pretty hard to push down until the point where the clutch begins to release. Then it eases up. Right now it's releasing pretty low. I plan to adjust it to release higher.
Normal or is something up ? |
rjames |
Jan 9 2007, 09:36 PM
I'm made of metal Group: Members Posts: 3,949 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Start with the easy stuff. Check your cable, clutch tube and pedal cluster.
Mine was this way until I replaced the cable- it was fraying where it goes around the plastic wheel under the rear trunk and would bind. If it isn't one of these, someone else will have to chime in as I haven't had to learn anything alese about transmissions yet (thankfully). |
ClayPerrine |
Jan 9 2007, 09:46 PM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
That can also be the symptoms of a worn out flywheel.
The 914 flywheel is a 2 step flywheel. It has a shoulder where the pressure plate mounts, and another where the disk rides. If the flywheel is ground down without cutting the shoulder the same amount, then the pressure plate geometry is screwed up. If it is cut far enough it can result in a very hard to push clutch pedal. After it gets past a certain point, it becomes lighter. That's when the plate gets back to the point where it should have started. The only way to verify this is to measure the flywheel. The specs are in the Haynes manual, both the 914 and 911 versions. |
Hammy |
Jan 9 2007, 10:00 PM
Robert, thanks. I'll go over the easy stuff first. Though my clutch cable is pretty new. It also appears my clutch tube has been repaired in the past, doesn't seem like it's loose or broken free. I'll check it though.
Clay, that makes sense. I can describe it as feeling like the clutch is either engaged or disengaged, and in between these is very small it seems. If it does turn out to be flywheel being too thin, how do I fix? Resurface? |
ClayPerrine |
Jan 9 2007, 10:09 PM
Robert, thanks. I'll go over the easy stuff first. Though my clutch cable is pretty new. It also appears my clutch tube has been repaired in the past, doesn't seem like it's loose or broken free. I'll check it though. Clay, that makes sense. I can describe it as feeling like the clutch is either engaged or disengaged, and in between these is very small it seems. If it does turn out to be flywheel being too thin, how do I fix? Resurface? Only proper fix is a new flywheel. You can, however cut the shoulder that the pressure plate bolts to down so that the dimension is correct per the factory spec. But you will have to put spacers under the ball pivot for the throwout arm, otherwise it will hit the case before the clutch disengages. BTDT...... (IMG:style_emoticons/default/headbang.gif) |
Hammy |
Jan 9 2007, 10:42 PM
Yeah..... my pivot ball already has 2 washers under it I believe.
Damn, new FW's are pricely. I have another spare flywheel laying around. How do I measure it? I just want a smooth operating clutch (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 05:41 AM |
