| bernbomb914 |
Nov 19 2003, 04:52 PM
one of the oldest Farts on this board ![]() ![]() ![]() Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I want to change the rod bolts on my new engine. where can I get some
Bernie |
| sj914 |
Nov 19 2003, 05:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
Try your nearest VW shop or a machine shop that does VW.
| Aaron Cox |
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
air cooled . net might have em (IMG:style_emoticons/default/wink.gif)
| bernbomb914 |
Nov 19 2003, 05:08 PM
Brad where do get your new bolts?
| Brad Roberts |
Nov 19 2003, 05:17 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
ARP. We dont use stock bolts on a complete rebuild.
B |
| bernbomb914 |
Nov 19 2003, 05:20 PM
how do I get in touch with ARP
Bernie |
| Brad Roberts |
Nov 19 2003, 05:30 PM
Here you go Bern..
http://www.arp-bolts.com/ And the part number. One day I will stock them. 104-6006 is the part number. B |
| Korijo |
Nov 19 2003, 05:34 PM
[]D o [] o []V[] o []D ![]() ![]() ![]() Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
I got a bag full of new ones w/ a NEW parts lot auction. Got 3 of each size of rear shims, too.
How many do you need, 7 ?? (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/wink.gif) PM me your address... |
| bernbomb914 |
Nov 19 2003, 05:41 PM
Thanks Dave e-mail sent
Bernie |
| Korijo |
Nov 19 2003, 05:52 PM
Just wanna make sure they are correct...
My PN is the same as the chart below. Right ones ?? BTW, its the bolt, NOT the bushing (IMG:style_emoticons/default/wink.gif) (see pic) Attached thumbnail(s)
| Brad Roberts |
Nov 19 2003, 05:55 PM
Dave has stock ones.
B |
| Korijo |
Nov 19 2003, 06:01 PM
Yea, and I guess I have NUTS, not BOLTS.
Sorry Bern... |
| DuckRyder |
Nov 19 2003, 06:59 PM
Avatars Mode: OFF because of the recalcitrant few. ![]() ![]() ![]() Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
Are the rod bolts required replacement?
| Zeke |
Nov 19 2003, 07:42 PM
Never left, but not right.... ![]() ![]() Group: Members Posts: 394 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
QUOTE(DuckRyder @ Nov 19 2003, 04:59 PM) Are the rod bolts required replacement? Recommended. But not required, according to RIMCO. But, at least use new nuts. Summit Racing has ARP for a lot less than going thru ARP themselves. |
| bernbomb914 |
Nov 19 2003, 11:38 PM
Thanks everybody got them at Summet $104.00 delivery in two days.
Bernie |
| mangrum |
Nov 20 2003, 12:52 PM
Member ![]() ![]() Group: Members Posts: 180 Joined: 10-September 03 From: Ann Arbor, MI Member No.: 1,134 |
Are the nuts included? They do not appear to be. I also need a set so let me/us know when they arrive.
| DuckRyder |
Nov 27 2003, 09:02 AM
O.K. More newbie T4 rebuild questions.
My rods check out dimensionally, can I replace the bolts without having to resize the big end? In addition, are the ARP Bolts anywhere near the same weight as the stockers? |
| bernbomb914 |
Nov 27 2003, 01:11 PM
I got my bolts and nuts Summit had them droped shipped from arp. arp will not sell them direct unless your are a distributor. you need to resize the rod ends after you install the new bolts for roundness. Brad does ARP make all the bolts and studs for the type 4 ?
Bernie |
| Mueller |
Nov 27 2003, 01:20 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,157 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Bernie,
I bought my ARP thru-case bolts and ARP head bolts from LN Engineering. He had a special if you bought both sets together. |
Lo-Fi Version | Time is now: 27th October 2026 - 09:21 PM |
