KenH |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 ![]() |
Brad,
Front struts must be stock. Bp class. Cannot get too low or will not have any shock travel. How do you determine the ride height?? Position of A-arms?? If so, parallel to ground or at what angle? Shock travel to stop dimension?? If fender lip - want size tires?? After the front is set do you adjust the rear for level or some amount of forward rake?? Ken |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Ken, its best to ask the question without my name in the actual title. That way you will get several good answers. I have the numbers here at the house.. but I need to leave. Look for a reply later tonight.
The rake is determined by cornerweights.. not by looks. We set the ride heigth and adjust for the cornerweights. b |
KenH |
As always, other comments are more than welcome.
Ken |
Bruce Allert |
Hellions asleep ![]() ![]() ![]() ![]() Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest ![]() |
I have a question regarding corner weight... what is it? How is this done & for what purpose.
I've heard it mentioned several times with hopes it would dawn on me or just be a common sence thing but no bright light has come on as yet (IMG:style_emoticons/default/blink.gif) bruce |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
It's a pimp term. Corner weighting is putting more girls in a high traffic area.
I think on cars, it refers more to balancing actual weight with an ass in the seat, and 4 scales. M |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,245 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(redshift @ Nov 19 2003, 08:42 PM) Corner weighting is putting more girls in a high traffic area. they usually use scales too! |
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
Bruce this may help in you search for knowledge of corner weighting.
http://www.grmotorsports.com/cornerweight.html CCLONTHECORNER |
Bruce Allert |
ah geeze, now the common sense flicked the switch to which the bright light went POOF
now I don't know what to believe... shit (IMG:style_emoticons/default/chair.gif) bruce (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/givemebeer.gif) |
KenH |
See - other comments did show up.
Ken |
KenH |
Bump
Brad Roberts |
Oh yeah.. I forgot.
20 3/4 on both rears thru the centerline of the wheel from ground to the stock fender lip. 21 7/8 on the right front thru the centerline of the wheel from ground to the stock fender lip 21 3/4 on the left front thru the centerline of the wheel from ground to the stock fender lip This will put the cornerweights very very close for you. I weigh 200lbs.. so it will be a tad different for you. All this is with 3/4 take of gas and the driver in the seat with 205/50/15 Hoosier road race tires. B |
Lo-Fi Version | Time is now: 6th July 2025 - 11:31 AM |
