KenH
Nov 19 2003, 05:33 PM
Brad,
Front struts must be stock. Bp class.
Cannot get too low or will not have any shock travel.
How do you determine the ride height??
Position of A-arms?? If so, parallel to ground or at what angle?
Shock travel to stop dimension??
If fender lip - want size tires??
After the front is set do you adjust the rear for level or some amount of forward rake??
Ken
Brad Roberts
Nov 19 2003, 05:42 PM
Ken, its best to ask the question without my name in the actual title. That way you will get several good answers. I have the numbers here at the house.. but I need to leave. Look for a reply later tonight.
The rake is determined by cornerweights.. not by looks. We set the ride heigth and adjust for the cornerweights.
b
KenH
Nov 19 2003, 10:07 PM
As always, other comments are more than welcome.
Ken
Bruce Allert
Nov 19 2003, 10:17 PM
I have a question regarding corner weight... what is it? How is this done & for what purpose.
I've heard it mentioned several times with hopes it would dawn on me or just be a common sence thing but no bright light has come on as yet
bruce
redshift
Nov 19 2003, 10:42 PM
It's a pimp term. Corner weighting is putting more girls in a high traffic area.
I think on cars, it refers more to balancing actual weight with an ass in the seat, and 4 scales.
M
Nov 19 2003, 11:55 PM
QUOTE(redshift @ Nov 19 2003, 08:42 PM)
they usually use scales too!
boxstr
Nov 19 2003, 11:59 PM
Bruce this may help in you search for knowledge of corner weighting.
http://www.grmotorsports.com/cornerweight.htmlCCLONTHECORNER
Bruce Allert
Nov 20 2003, 12:02 AM
ah geeze, now the common sense flicked the switch to which the bright light went
POOF now I don't know what to believe...
shit
bruce
KenH
Nov 20 2003, 12:47 AM
See - other comments did show up.
Ken
KenH
Nov 21 2003, 12:46 AM
Bump
Brad Roberts
Nov 21 2003, 01:01 AM
Oh yeah.. I forgot.
20 3/4 on both rears thru the centerline of the wheel from ground to the stock fender lip.
21 7/8 on the right front thru the centerline of the wheel from ground to the stock fender lip
21 3/4 on the left front thru the centerline of the wheel from ground to the stock fender lip
This will put the cornerweights very very close for you. I weigh 200lbs.. so it will be a tad different for you.
All this is with 3/4 take of gas and the driver in the seat with 205/50/15 Hoosier road race tires.
B
