KenH |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 ![]() |
Brad,
Front struts must be stock. Bp class. Cannot get too low or will not have any shock travel. How do you determine the ride height?? Position of A-arms?? If so, parallel to ground or at what angle? Shock travel to stop dimension?? If fender lip - want size tires?? After the front is set do you adjust the rear for level or some amount of forward rake?? Ken |
Lo-Fi Version | Time is now: 6th July 2025 - 01:39 AM |
